My 1975/77 Baja
Page 2 of 2 Previous  1, 2
My 1975/77 Baja - Page 2 Empty Re: My 1975/77 Baja
Post by bakertim2 on Mon Dec 21, 2015 9:26 pm
Getting it done. Keep on bajaing.
Post by Heinz57 on Sun Mar 20, 2016 8:46 pm
Here's an update: Been pretty busy the last 3 weeks. Completely stripped the pan down to bare metal, welded up the loose spots. Had to go with an adjustable shift coupler, the 10 degree mount kit made the shift rod too long. Tried out the Master Series silver and Satin Black paints. Silver worked well but the black is way too thick to spray less roll it on as I did. Got the rear brakes adjusted and P brake works good. Had to shorten the Bowden tube with the 002 tranny. and everything is working. I also sprayed the Raptor Bedliner on the bottom and framehead area on the pan. Came out pretty nice. Only spray this stuff outside, even with my 3M mask you could smell it while working. Saving up some money to get the front tires, 7.00 x 15" Power King Super Traction IIs and Epoxy primer for the body. I also switched from the stock width front beam to a 6" wider version and now thr Rack-n-pinion mount does not work since there are 4 adjusters and the top 2 beam adjusters are exactly where the rack mounts sits. Need to order that new mount too. Enjoy the update.
Front beam bars added:
My 1975/77 Baja - Page 2 Lt_fro10
Rt front suspension with all new 10.9 and grade 8 hardware:
My 1975/77 Baja - Page 2 Rt_fro10
Completed front end:
My 1975/77 Baja - Page 2 Comple10
Pedals, MC, lines and shifter in:
My 1975/77 Baja - Page 2 Front_10
Rear Suspension Completed, tranny was wire brushed:
My 1975/77 Baja - Page 2 Transm10
Added Center caps to the BFG Tires and Wheels:
My 1975/77 Baja - Page 2 Img_2010
Completed rear suspension before 002 Transmission was installed:
My 1975/77 Baja - Page 2 Comple11
Heinz57
Heinz57
Number of posts : 374
Post by Attorney Isaiah Loophole on Sun Mar 20, 2016 9:45 pm
Looks awesome!
Post by Heinz57 on Mon Mar 21, 2016 8:59 pm
Thanks Bryce, here are a few more pics of the bedliner I sprayed on the pan. The bedliner coating was still wet, it flattened out color wise when it dried.
My 1975/77 Baja - Page 2 Rator_12
My 1975/77 Baja - Page 2 Raptor12
Heinz57
Heinz57
Post by zabo on Tue Mar 22, 2016 6:39 am
nice work! its looking really good. hope the steering isnt too hard to work out.
Post by Heinz57 on Sat Mar 26, 2016 11:10 am
Thanks, Zabo, I think I have the rack mounting situation figured out. I used the original butterfly style mounts and modified one mount into 2 outer mounts.
Heinz57
Heinz57
