Sticking Brake pedal
Post by rpm750 on Thu Jan 22, 2009 8:23 pm
I have great brakes on my car. Disk on the front and 68 drum on rear. I have to reach down and pull the pedal the rest of the way out to keep the brakes from dragging. They really don't drag to bad but I think its enough to cause brake heat and unnecessary wear.
Also these disk pads sure do cause a lot of dust. More than I remember from my 68 I had back in the 80's.
Not sure if its the pedal or the Master Cylinder.
Re: Sticking Brake pedal
Post by DiggerD on Thu Jan 22, 2009 8:33 pm
I would start by rebuilding the pedal cluster and replacing the return spring while its apart. Just did this last year, its not too hard and in my case, greatly improved the pedal action on brake,clutch and accel.
DD
Post by jshmnghm on Thu Jan 22, 2009 8:44 pm
dont know if they are available, but ceramic pads (not race pads, just ceramic replacements) will produce much less dust.
Number of posts : 311
Post by rpm750 on Thu Jan 22, 2009 9:02 pm
Hey Digger, Return spring for the clutch or brake? I don't have a spring on my pedal cluster. AH! Suspect
Post by DiggerD on Thu Jan 22, 2009 9:24 pm
You are correct!! Only if you were one year younger.................
DD
Post by 71_georgia_beetle on Thu Jan 22, 2009 11:52 pm
You can find a kid with a trampoline, swipe one of the springs and hook one end on the pedal and the other to your seat. Problem solved. clown
Post by 57RTOval on Fri Jan 23, 2009 5:10 pm
Has the residual pressure valve been removed from your master cylinder? That will also cause your disc brakes to drag. My kit from SoCal Auto Parts had a larger bore Bus master cylinder and it still had the valve in it, causing my brakes to drag (only the front discs). The rotors got hot enough to smell them and it started to lose grease from the hubs. Removing the valve cured everything.
Pete
Number of posts : 529
Post by rpm750 on Fri Jan 23, 2009 7:51 pm
Hey 57RTOval, I'm not sure what you are talking about, there is nothing on the outside to remove other than the tubes that hook to the reservoir? I think my problem is the spring. I have it on the clutch, but it already has a return spring on the trans and the pressure plate will help push it back also.
I've checked my rotors when I get home and they are cool to the touch, not hot at all. I'm going to move that spring, I'm sure thats it. Now I think the brake dust is from the pads them selves. Now that I know the pedal is keeping pressure on the brakes I reach down and pull it back. So there is no real dragging. My wife's Astro van is real bad with brake dust, on all four wheels! May try to find some Ceramic or Metallic type pads.
BTW, I have great braking power, so much so that I can't slide the fronts. It just stops!!
Eat your heart out Ferdinand Porsche! I love European brakes!
Update
I have tracked down my brake pedal problem, it is the spring. It goes behind the brake pedal. I moved it a couple minutes ago and it returns perfect. Embarassed
Post by 57RTOval on Fri Jan 23, 2009 10:28 pm
Sounds like the pedal spring will cure your problem.
The residual pressure valve is buried deep within the master cylinder. It's the last part that will come out when you disassemble it. Don't worry about it. Fix your pedal spring first and see if that fixes it.
