Clutch tube repair
Clutch tube repair
Post by peregrine67 on Fri Dec 07, 2012 8:34 am
Anybody here done this?
http://www.thesamba.com/vw/forum/viewtopic.php?t=236748
Any advice you could give before I cut open my '67 tomorrow?
Number of posts : 1343
Re: Clutch tube repair
Post by pwmcguire on Fri Dec 07, 2012 9:53 am
I have no advice but, "good luck" there is a lot of support on the samba, but you know that. If you were closer I would come help, just to learn.
Number of posts : 787
Post by type4revolution on Fri Dec 07, 2012 10:21 am
? Do you know where its broken. Well before you make your tunnel swiss cheese take a bore scope and look inside for the break. Then cut accross from the break so you can gain access to weld up tube and ad support to that area. Warning do melt clutch tube be careful and before you repair loosen cable till its slack. After I reapir break I wrap a piece of sheetmetal around tube an weld to tunnel for added strength. need info feel free to contact me
Number of posts : 907
Post by Clyde on Sat Dec 08, 2012 6:39 am
Sorry about the non existent pics, this is from a few years ago. There are measurements listed, so you cut in the right spot. Skip the hole saw, use a cut off wheel instead, that way you can bend it back into place and weld it shut- keeps the tunnel strong.
Hope it goes well Michael!
http://www.athensvwclub.com/phpBB2/viewtopic.php?t=1022
Clyde
Number of posts : 278
Post by peregrine67 on Tue Dec 18, 2012 5:46 pm
thanks. I'm gonna tackle it today.
