floor pans
floor pans
Post by bigdog1 on Mon Jan 19, 2009 3:53 pm
When replacing rusted floor pans ,which is the better way to fasten the new pans to the frame... weld , rivet or screw? I don't have access to a welding rig so I'm left with using rivets or screws . Anybody care to give their thoughts on this?
Thanks
bigdog1
Number of posts : 5
Registration date : 2009-01-10
Re: floor pans
Post by fearthefat138 on Mon Jan 19, 2009 3:59 pm
WELD THEM Shocked
fearthefat138
Number of posts : 275
Re: floor pans
Post by 69panel on Mon Jan 19, 2009 5:25 pm
Screw them and drive to someone who will weld them.
Number of posts : 459
Re: floor pans
Post by vwovalchild on Mon Jan 19, 2009 5:39 pm
Weld only
Number of posts : 895
Re: floor pans
Post by 71_georgia_beetle on Mon Jan 19, 2009 5:53 pm
Chicken shits, just hot glue em'.
Re: floor pans
Post by bigdog1 on Mon Jan 19, 2009 5:56 pm
So ,what does it cost get the pans welded?
bigdog1
Number of posts : 5
Re: floor pans
Post by 71_georgia_beetle on Mon Jan 19, 2009 6:12 pm
I'm not sure if they charge hourly, legnth of weld or by job but you may find someone on here to get it done fairly cheap but if it gets close to the $250 side you could buy a welder and do it yourself. http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200342925_200342925
Re: floor pans
Post by skunk on Wed Aug 26, 2009 8:40 am
lol..hot glue,thats funny as hell...yea dude weld only.you screw or rivit you mite be lower than the car while your driving down the road.my old set of floor pans were rusty floor pnas,road signs,fiberglass and wood. it worked for a while till everything in the floorboards were flyin all over the highway..lol..it was cool...but ya dude weld
skunk
Number of posts : 218
Re: floor pans
Post by Bugman114 on Wed Aug 26, 2009 2:40 pm
i'm partial to mighty putty, afterall, it supposed to be able to pull a fully loaded semi truck, right?....... Laughing , lol, jk
Re: floor pans
Post by tronview on Wed Aug 26, 2009 3:18 pm
I am currently working on a complete pan replacement. My passenger side pan had been replace by a body shop that the previous owner hired. The body shop in all there wisdom installed the pan with two tack-welds and what looks like roofing compound. I was able to remove the pan with one swift kick. Oh and one more thing. The seat guides were mounted using six pop rivets which had pulled out and left the car without a passenger seat.
The best way to install your pans would be to remove the old pans, grind the center channel lip clean and smooth, tightly fit your pan to the channel. This may take a little more grinding. Then Tack weld the pan in with a tack every inch. Once done apply a nice coating of seam sealer where the pan meets the channel. Don't forget when tacking the pan first put a tack down every 12 inches then come back and do it every 6 inches, then every 3 then 1 . This will keep the pan from bowing and getting out of alignment.
Buy the way call around to welding supply companies. some of them will let you rent a Mig welder.
Number of posts : 464
Re: floor pans
Post by zabo on Wed Aug 26, 2009 3:48 pm
who rents migs? anybody have any names?
Re: floor pans
Post by tronview on Wed Aug 26, 2009 4:11 pm
zabo wrote:who rents migs? anybody have any names?
Northside Tool Rental in Norcross has a 90 amp 110V Mig welder setup for Flux Core wire. They are asking $30.16 per day to rent it.
Norcross.
1547 Beaver Ruin Rd.
Norcross, GA 30093
770-923-2620
Mon-Fri 7:30-5:30
Saturday 7:30-Noon
Re: floor pans
Post by Grifspop on Wed Aug 26, 2009 8:32 pm
You never know, you might could get a muffler shop to weld them, that's what they do is weld exhaust pipes and mufflers all day, plus they have the lifts to work under.
Re: floor pans
