Jon65's 65
+17
ridikas
Murdock00
mike hardigree
redneck_davis
Cave Man
21 posters
Page 1 of 5
Page 1 of 5 • 1, 2, 3, 4, 5
Jon65's 65
I thought I would start a thread for my bug. Seeing how it will soon be painted and worked on to bring it to show worthy condition, I can post some of the progress when the painting begins.
Here's my car. More pics to come as I find them on my computer.
Thanks for looking. Any comments/advice are welcome.
Jon65- Complete Dub Addict
- Number of posts : 875
Re: Jon65's 65
Here's the newest pic of the motor that I have. It will be different when it's out of the shop though, because it will have a single carb on it.
Here's the engine specs as of today.
Engine
1974 1600 case
Displacement: 1641 cc
Bore: 87mm
Stroke: 69mm
Carb: Dual Weber 34 ICT
Single port heads
Cam: unknown
Exhaust: EMPI Single Quietpack Extractor System
Ignition: 009; breaker point style
Transaxle: Freeway Flyer
Gear Ratio:
1st gear: 3.80
2nd gear: 2.06
3rd gear: 1.32
4th gear: 0.89
Ring and pinion (final drive ratio): 3.88
Engine
1974 1600 case
Bore: 87mm
Stroke: 69mm
Single port heads
Cam: unknown
Gear Ratio:
1st gear: 3.80
2nd gear: 2.06
3rd gear: 1.32
4th gear: 0.89
Re: Jon65's 65
Looks very nice.
Cave Man- Dub Nut
- Number of posts : 333
Re: Jon65's 65
Nice.
Real clean
Real clean
redneck_davis- Dub Nut
- Number of posts : 188
Re: Jon65's 65
Jon65 wrote:Seeing how it will soon be painted and worked on to bring it to show worthy condition, I can post some of the progress when the painting begins.
Nice car, looks show worthy already! What was wrong with the dual carbs?
Re: Jon65's 65
Cave Man wrote:Looks very nice.
Thanks man.
Re: Jon65's 65
redneck_davis wrote:Nice.
Real clean
Thanks, you should see how long it takes for me to wash it. If I haven't cleaned it completly inside and out, to me, I haven't cleaned it well enough.
Re: Jon65's 65
fluxcap wrote:What was wrong with the dual carbs?
The throttle arm bushings had worn themselves out and began to have too much play in them. When I was told this I had 2 options: 1 to go and spend money on new carbs, linkage, and hardware; or 2 use the stock single carb and manifold that I had left over from where I converted it to dual carbs. So I bit the bullet and as of the end of this week, I will have a single carb. But it's ok, as long as I get to drive my bug, it's fine by me.
Still, I was kinda disapointed that I can't have my fast looking dual carbs. I guess I'm a dual carb person stuck with a single now.
Re: Jon65's 65
You could of had the carbs rebushed. There is even someone local in Monticello that does it
Re: Jon65's 65
Attorney Isaiah Loophole wrote:You could of had the carbs rebushed. There is even someone local in Monticello that does it
There is?
I was informed that they had to be shipped out to CA to be properly rebushed.
Oh well. Besides, I think I will get them back from the shop, so I'll just put them up in case I do want to rebush them and rerun them again.
Re: Jon65's 65
Here is his ad:
http://www.thesamba.com/vw/classifieds/detail.php?id=1362329
Re: Jon65's 65
fluxcap wrote:Here is his ad:
Thanks for the help. I'll look into it.
Re: Jon65's 65
Here's a couple more pics that I found of the trunk and interior.
Again, sorry for the pic being sideways.
Re: Jon65's 65
Beautiful bug! Is that Bahama Blue? Looks great!!
drvr8- Dub Nut
- Number of posts : 127
Re: Jon65's 65
drvr8 wrote:Beautiful bug! Is that Bahama Blue? Looks great!!
Thanks. Right now it is just a quick enamel paint job that the PO put on to sell it. But it will be repainted as Bahama Blue.
Re: Jon65's 65
While going through my pictures, I found a couple of pics from the 2010 Y U Buggin' show. So I thought you guys would like to see um'.
Re: Jon65's 65
Here's the motor back then. Not much change though.
Re: Jon65's 65
See if you can find mine.
Re: Jon65's 65
Here's a pic that I liked the most. As we lined up to go around the track, my car ended up right next to two Herbies. It was awesome.
Last edited by Jon65 on Sun Dec 23, 2012 6:34 pm; edited 1 time in total (Reason for editing : spell check)
Re: Jon65's 65
Where is that show? Thats what color my baja used to be. Or close.
Re: Jon65's 65
redneck_davis wrote:Where is that show?
It's the Y U Buggin show that goes down at the Atlanta Motor Speedway every June. You should come to the next one.
Re: Jon65's 65
Well, the car comes back from the shop this weekend. Can't wait to drive it a good bit.
Re: Jon65's 65
What all you getting done at the shop?
Re: Jon65's 65
fluxcap wrote:What all you getting done at the shop?
Just a complete tune up of the motor. I was gonna get it in perfect tune that way when I start maintaining it myself, I have a good guideline to follow as far as timing and carb adjustments go.
And also replacing the dual carbs with a single one. I can already do this myself, but I figured I might as well let the shop do it while it is already there.
Page 1 of 5
