Best push rod tubes or best way to prevent leaks
Best push rod tubes or best way to prevent leaks Empty Best push rod tubes or best way to prevent leaks
Post by PeeWeeMan91 on Thu Oct 04, 2012 7:53 am
Hey so still can't get these tube to stop leaking what the best option?
PeeWeeMan91
PeeWeeMan91
Number of posts : 567
Best push rod tubes or best way to prevent leaks Empty Re: Best push rod tubes or best way to prevent leaks
Post by zabo on Thu Oct 04, 2012 8:05 am
you using stock tubes or spring loaded?
If using spring loaded I would try these scat ones with the internal springs-
I ran these for 2 years without any problems. I think you can buy them by the set or individually.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C15-20175
But the best option of course is pulling the heads and using new stock tubes- Just make sure the seals are in good and the end of the tubes are seated correctly before tightening down the heads.
Post by bakertim2 on Thu Oct 04, 2012 8:49 am
If using stock pushrod tubes, they must be stretched at each end and make sure when you put them in that the welded seam is facing upward toward the cylinders. You also can use a light coat of aviation sealant on the seals.
Post by PeeWeeMan91 on Thu Oct 04, 2012 12:07 pm
PeeWeeMan91
PeeWeeMan91
Post by camch on Thu Oct 04, 2012 1:28 pm
Empi spring loaded is what my race motor has and no leaks
camch
camch
Number of posts : 660
Post by Hookdriver on Fri Oct 05, 2012 7:23 pm
I have never had any issues with stock tubes. The mating surfaces have to be 100% clean. Once they look clean use a bit of laquer thinner or denatured alcohol and wipe the down. Stretch the tubes a bit, not much, and ensure the seams are up. A VERY light coat of oil on the seals if you are going to use anything. I put them in dry. I keep two of the spring loaded tubes in my onborad spares box so I wont have to pull a head in the middle of nowhere. The biggest thing that helps is keeping the mating surfaces clean. If you continue to have issues you may want to pull tins and check head torque.
Hookdriver
Hookdriver
Number of posts : 156
Post by vw57drvr on Mon Oct 08, 2012 9:24 am
Yamabond from the yamaha dealer. Very good stuff for VW engines.
Post by atye on Tue Oct 23, 2012 2:31 pm
I run these:
Best push rod tubes or best way to prevent leaks 1558
http://www.cbperformance.com/catalog.asp?ProductID=120
I always had problems with stock tubes for whatever reason. These are easy to install and damn near bullet-proof.
atye
atye
Number of posts : 259
