1970 Karmann Ghia
Page 1 of 2 1, 2  Next
1970 Karmann Ghia Empty 1970 Karmann Ghia
Post by Hobug on Sat Aug 04, 2012 11:27 am
I have been working on getting my sister-in-law's Ghia roadworthy for a while and I am finally making some real progress. Once I have it running and driving I will hand it over to my sis-in-law. She will then be looking for guidance from the Atl Wagens group. As I am too lazy to repost everything here,
please follow the link to the pictures.
http://www.athensvwclub.com/phpBB2/viewtopic.php?p=10245#10245
Number of posts : 1325
1970 Karmann Ghia Empty Re: 1970 Karmann Ghia
Post by Hobug on Thu Aug 09, 2012 12:26 pm
Ok, I have a little more energy today so I'm posting pictures here too.
Here are a few more pics of the progress. Kat came to help sand, prime, seal, and paint her floors.
1970 Karmann Ghia Plantpics079
1970 Karmann Ghia Plantpics082
1970 Karmann Ghia Plantpics084
1970 Karmann Ghia Plantpics088
1970 Karmann Ghia Plantpics089
1970 Karmann Ghia Plantpics090
I still have to turn it over and do the underside.
Post by zabo on Thu Aug 09, 2012 12:45 pm
you didnt like the fiberglass pans? Laughing
Post by Grifspop on Thu Aug 09, 2012 3:24 pm
Where do the bolts go through to the body? scratch
Post by Hobug on Thu Aug 09, 2012 3:50 pm
Grifspop wrote:Where do the bolts go through to the body? scratch
Yeah, what happen to the good old days when you didn't have to do everything yourself? There are dimples where the hole are to be drilled, but I don't trust them to be in the right spots.
Post by Grifspop on Thu Aug 09, 2012 3:53 pm
Yeah, Jon, I'm sorry that I missed the body lift party- but you seem to be knocking this one out!
Post by DiggerD on Wed Aug 15, 2012 7:52 pm
Thats them "one size fits all" pans...................... Razz
Post by Hobug on Tue Oct 02, 2012 9:23 pm
I've been pretty slack about workin on the Ghia, so Saturday I'm going to install the shifter bushings, new shocks, shift coupler, and install new cables. If I'm really on a roll I might even paint the front beam. Cool
Post by Hobug on Wed Nov 28, 2012 10:09 pm
Back on the ghia. Beam is off and painting the frame head. Found a spot that needs to be welded on the shock tower. Pictures soon.
Post by Jon65 on Wed Nov 28, 2012 10:14 pm
Hobug wrote:Pictures soon.
Sounds good.
Post by Hobug on Fri Nov 30, 2012 6:52 pm
So I've moved the pan inside to work on it. I started on the front beam and was just going to clean and paint it before putting on the new brake hoses.
1970 Karmann Ghia BugjamThnksgvngGhia075
Well as usually happens with VWs, I found some rust holes. These were in the shock tower, so I pulled the beam and cleaned and painted the frame head while it was exposed.
1970 Karmann Ghia BugjamThnksgvngGhia080
1970 Karmann Ghia BugjamThnksgvngGhia082
1970 Karmann Ghia BugjamThnksgvngGhia089
I took the beam to the car wash and degreased it last night. Now I'll take it to get welded, then I'll finish cleaning and paint it.
While at Bug Jam I got a used shifter for $5.00 (thanks Clyde). I don't have the before picture, but here it is after I finished with it.
1970 Karmann Ghia BugjamThnksgvngGhia069
Post by zabo on Fri Nov 30, 2012 7:42 pm
lookin good!
Post by Jon65 on Fri Nov 30, 2012 8:13 pm
Yeah, that's an awesome job.
Post by tronview on Fri Nov 30, 2012 9:19 pm
Nice work Jon. Keep it up.
Number of posts : 465
Post by Hobug on Fri Nov 30, 2012 10:40 pm
Thanks guys. I've got a football game to go to tomorrow, but I'll be back on it Sunday. GO DAWGS!!!
Post by Jon65 on Fri Nov 30, 2012 11:33 pm
Hobug wrote:GO DAWGS!!!
A big X2. Very Happy
Post by Hobug on Mon Dec 03, 2012 11:04 pm
Took the beam to Clyde and he removed the trailing arms so he can install new ball joints. I brought the rest of it home for cleaning and paint.
Painted the backing plates. Cleaned the lug bolts and other nuts and bolts in the vibrating cleaner. (kinda like a rock polisher)
Post by Hobug on Wed Dec 05, 2012 11:00 pm
Here are some pics:
The rusty parts of the shock tower. It is only on one side and I am going to get it welded up.
1970 Karmann Ghia SECXmastreeGhia028
1970 Karmann Ghia SECXmastreeGhia029
Backing plates before cleaning and painting.
1970 Karmann Ghia SECXmastreeGhia038
1970 Karmann Ghia SECXmastreeGhia039
Spindles before:
1970 Karmann Ghia SECXmastreeGhia040
1970 Karmann Ghia SECXmastreeGhia041
Grub screws before and after:
1970 Karmann Ghia SECXmastreeGhia044
Backing plates after:
1970 Karmann Ghia SECXmastreeGhia042
1970 Karmann Ghia SECXmastreeGhia043
Brake push rod:
1970 Karmann Ghia SECXmastreeGhia045
Post by Hobug on Wed Dec 05, 2012 11:07 pm
Front end nuts and bolts
1970 Karmann Ghia SECXmastreeGhia053
Several of the parts painted and ready
1970 Karmann Ghia SECXmastreeGhia054
Post by Guest on Sat Dec 08, 2012 4:46 pm
alot of work will pay off
Guest
Guest
Post by Hobug on Sun Dec 16, 2012 5:58 pm
Rust is cut from the beam and it is welded up. Thanks Joe. Very Happy
Post by bayboy87 on Sun Dec 16, 2012 6:23 pm
did you use a tumbler or a wire brush to clean the bolts? i have alot of rusted bolts
bayboy87
bayboy87
Number of posts : 246
Post by Hobug on Sun Dec 16, 2012 6:39 pm
bayboy87 wrote:did you use a tumbler or a wire brush to clean the bolts? i have alot of rusted bolts
Wire brush in the drill, but many times I will use the tumbler and finish them with the wire brush.
Post by Hobug on Fri Jan 04, 2013 6:20 pm
Trailing arms are ready to go. New ball joints installed thanks to Clyde. I put my son to the task of cleaning the spindles to prepare for painting and then I primed and painted them.
1970 Karmann Ghia Ghia001_zps4e0b39a8
1970 Karmann Ghia Ghia003_zpsfaa23f8a
1970 Karmann Ghia Ghia006_zps2c143ea7
Post by pwmcguire on Fri Jan 04, 2013 7:04 pm
You gotta use the lazy mans rust and paint remover, just wire it up and let it go. It works great. If you build a big enough box you could put the whole front axle assembly in it.
http://forum.georgiadubs.com/t5891-rust-removal-by-electrolysis
Number of posts : 787
