In need of bolts
In need of bolts Empty In need of bolts
Post by rpm750 Tue Jul 03, 2012 8:56 pm
I need (2) 14mm by about 50mm long bolts. Lowe's, HD, AutoZone, Advance and Tractor Supply do not carry anything larger than 12mm. Who do you think will have them?
http://forum.georgiadubs.com/
In need of bolts Empty Re: In need of bolts
Post by fluxcap Tue Jul 03, 2012 9:00 pm
Are these the same size as the bolts that hold the beam to the frame head?
Post by fluxcap Tue Jul 03, 2012 9:02 pm
Nope, looked it up on samba, those look to be 12. I know the ace in Fayetteville had a pretty good selection of hardware. Found some hard to find stuff there once.
Post by pwmcguire Tue Jul 03, 2012 9:26 pm
Threads of the south in Marrietta my have them, down behind the coke plant on 41. Let me know, I work in the same area, I can pick them up if they have them
Number of posts : 787
Post by rpm750 Wed Jul 04, 2012 10:46 am
Thanks guys, there is a Fastenal in PTC. Closed today but I'll check them out after the holiday. Will check out the Ace in PTC.
Post by sploval53 Wed Jul 04, 2012 11:11 am
The ace I'n Fayetteville closed for good a couple months ago
Number of posts : 1416
