brake issue
brake issue
Post by zabo on Tue Jun 19, 2012 1:43 pm
So ive been driving the 60 daily the past few weeks- the other day I was on a crazy steep hill near my job and was really jamming on the brakes-
all of a sudden the pedal went to the floor. Luckily my ebrakes working good Shocked
anyway all the lines are good/fairly new- didnt see any fluid coming from the wheel cylinders.
The only place i noticed some fluid was around the brake fluid reservoir cap.
Any idea why this would happen? A few pumps and I had good pedal again.
sound like just bad MC?
Re: brake issue
Post by laith on Tue Jun 19, 2012 2:11 pm
zabo wrote:So ive been driving the 60 daily the past few weeks- the other day I was on a crazy steep hill near my job and was really jamming on the brakes-
Possibility that you boiled the fluid at the wheel cylinders. Crazy steep hill + drum brakes = lots of heat. I would recommend a complete fluid flush and re-bleed.
Out of curiosity, do you have a single or dual circuit m/c?
laith
Number of posts : 298
Re: brake issue
Post by peregrine67 on Tue Jun 19, 2012 2:13 pm
zabo wrote:sound like just bad MC?
That would be my first guess. If you end up replacing it I'd consider upgrading to a dual circuit MC too. Not sure how much trouble that would be for a '60 but it might be worth it.
Number of posts : 1343
Re: brake issue
Post by zabo on Tue Jun 19, 2012 2:19 pm
i dont think i boiled the brakes- I had just started the car- pulling out of the parking lot at work.
its a single master cylinder
Re: brake issue
Post by Clyde on Fri Jun 29, 2012 11:49 am
You probably have a oring with a flat spot on it in the mc. Works most of the time, and suprises you when it feels like it.
If you had a dual circuit setup you would have only lost half of your brakes. It's more expensive, but who cares if it saves your life, or an expensive body shop bill.
Clyde
Number of posts : 278
Re: brake issue
Post by zabo on Fri Jun 29, 2012 2:17 pm
i think i figured it out- bad grommet where reservoir hose goes in- under a lot of pressure fluids coming out there
Re: brake issue
Post by zabo on Thu Jul 05, 2012 8:06 am
so i guess I was wrong- got a nice new german grommet - no leaks there now.
Replaced the Master Cylinder as well. Seems to have good pedal, only when im on a hill or just apply constant even pressure to it will it go to the floor
driving me crazy- i havent pulled the back wheels off yet- but im not seeing any fluid dripping around the wheel cylinders
Re: brake issue
Post by Clyde on Thu Jul 05, 2012 9:14 am
How's the main steel line under the pedal cluster? Rust attacks there unnoticed...
Might be a hole small enough to hold pressure most of the time.
Clyde
Re: brake issue
Post by vw57drvr on Thu Jul 05, 2012 10:13 am
Randomly going to the floor almost has to be the master cylinder "bypassing". What kind of cylinders are you using?
Number of posts : 901
Re: brake issue
Post by zabo on Thu Jul 05, 2012 11:04 am
ill check out the lines again
using Vargas
Re: brake issue
Post by vw57drvr on Fri Jul 06, 2012 6:56 pm
Those are pretty good. Is that the brand of master cylinder too?
Re: brake issue
Post by zabo on Fri Jul 06, 2012 7:45 pm
yep - my sons taking the wheels off now as i relax in the ac- going to double check all the wheel cylinders- then prob try replacing the soft lines in case they may have collapsed inside or something.
all the hardlines look good.
Re: brake issue
Post by vw57drvr on Fri Jul 06, 2012 10:57 pm
Collapsed lines wont normally do that but good idea to check anyway. What kind of reservoir?
Re: brake issue
Post by zabo on Sat Jul 07, 2012 8:01 am
stock 60 metal reservoir
Re: brake issue
