Need help with Alternator
Need help with Alternator Empty Need help with Alternator
Post by Brian68 on Tue May 15, 2012 10:17 am
Hey guys I need a little help with an alternator. I think my voltage regulator is bad, it's putting out about 14.8v @idle and 18@ at driving speeds. It has an internal voltage regulator but I'm not sure where it is located in the alternator to replace it.
Thanks
Brian
Brian68
Brian68
Number of posts : 25
Registration date : 2011-06-20
Need help with Alternator Empty Re: Need help with Alternator
Post by SavannahVW on Tue May 15, 2012 7:39 pm
Brian, I have a 75 & 95 amp alternators on my bug and bus. Since these alternators have internal regulators it is not necessary to use the stock voltage regulator. I recommend you take it out of the system. You will have to do some wire bridging but it will even out your voltages.
SavannahVW
SavannahVW
Number of posts : 136
Post by pwmcguire on Tue May 15, 2012 9:02 pm
Brian68 wrote:Hey guys I need a little help with an alternator. I think my voltage regulator is bad, it's putting out about 14.8v @idle and 18@ at driving speeds. It has an internal voltage regulator but I'm not sure where it is located in the alternator to replace it.
Thanks
Brian
I dont think you can replace it, You have to replace the whole alternator.
Number of posts : 787
Post by DubsforLife on Mon May 21, 2012 7:59 am
I take mine and have them rebuilt at a guys shop down the road from me
DubsforLife
Number of posts : 34
Registration date : 2011-12-31
Post by adams77 on Mon May 21, 2012 10:16 am
If its an AL 82 you can buy replacement brushes and regulators for around $30 each.
adams77
Number of posts : 257
Registration date : 2009-01-09
Post by Brian68 on Mon May 21, 2012 12:07 pm
adams77 wrote:If its an AL 82 you can buy replacement brushes and regulators for around $30 each.
Are they hard to replace?
Brian68
Brian68
Post by adams77 on Mon May 21, 2012 12:12 pm
EASY!
Screwdriver and pliers, done in 10 min!
http://www.cbperformance.com/catalog.asp?ProductID=850
adams77
Post by Brian68 on Tue May 22, 2012 6:43 am
adams77 wrote:EASY!
Thanks Adam... I took the alternator off and apart last night and got the voltage regulator out. I didn't see any number on the regulator but I will order the Bosch one.
Brian68
Brian68
