Pulley Nut removal
Pulley Nut removal
Post by type901 on Sun May 06, 2012 1:07 pm
So my drive pulley is warped and is eating up belts after about 100 miles. I bought an aluminum degree pulley but after a couple of hours trying to come up with a pulley lock or something the warped one is still on the motor. Is there a certain trick to hold the pulley while I break the nut? USing 3/4 drive with a breaker and no dice. Is this a nut an impact works better on or is there a tool that locks it down to break it loose?
Thanks
Phillip
type901
Number of posts : 543
Re: Pulley Nut removal
Post by pwmcguire on Sun May 06, 2012 8:41 pm
An impact gun would work well, but I do not know if there is enough room to get it in, you my have to use a swivel. If it is warped you could try (dare I say) vice grips clamped on to the drive pulley to stop it or hold onto it. You could also apply a little heat to the pully
Good luck
Pat
Number of posts : 787
Post by callahan on Sun May 06, 2012 8:59 pm
just yank off the apron and rear tin and blast it off with an impact. easy peasy
Number of posts : 1271
Post by type901 on Sun May 06, 2012 9:01 pm
Thanks, I thought as much. I had the apron and tin off with the breaker. The bentley just said remove nut, I thought well either it is that easy or I am an idiot. Will grab an impact tomorrow.
type901
Post by type901 on Mon May 07, 2012 7:59 pm
callahan wrote:just yank off the apron and rear tin and blast it off with an impact. easy peasy
I knew it was a stupid question, I been holding off on buying an impact. Spun right off and now I have a true pulley so maybe I can cut back on 2 belts a month.
Thanks Callahan and pwmcguire.
type901
