72 Bay Bus
Page 1 of 2 1, 2  Next
72 Bay Bus Empty 72 Bay Bus
Post by 67vdub on Thu May 03, 2012 10:36 pm
My new Bay Bus i just picked up today. The PO said it was a 72 not sure i have to look up the Vin to make sure.........It was a great deal i could not pass it up......Parts list to come. Very Happy 72 Bay Bus 471916_3103795638295_1366360911_2243754_941810105_o
72 Bay Bus Empty Re: 72 Bay Bus
Post by bakertim2 on Thu May 03, 2012 10:49 pm
Sure looks like a 72 to me.
Post by 67vdub on Thu May 03, 2012 11:32 pm
The only reason I question is because the location of the blinkers. Tim what is the best way to lower a Bay?
Post by Muffler Bearing on Fri May 04, 2012 6:00 am
Yeah. Them lenses are up kinda high for a 72.
Number of posts : 731
Post by rpm750 on Fri May 04, 2012 6:42 am
Could be a late '72. VW would use up what they had from pryer year then start using the new stuff even if it was a miss match like this one. Also the nose might of been replaced at some point from a big hit in the front. Never know.
Post by 67vdub on Fri May 04, 2012 10:03 am
72 Bay Bus Photobucket-56448-1336112787122
Post by 67vdub on Fri May 04, 2012 10:09 am
72 Bay Bus Photobucket-1209-1336112874056
Pic of the Bay on its way home.thanks on the info of the 72Bay parts i looked it up 72 it is.......
Post by DOODLE BUGG on Fri May 04, 2012 6:24 pm
take a pic of thefront end it has a 72 front bumper with a later nose on it i would love to see more pics how low you want to go
Post by 67vdub on Fri May 04, 2012 7:31 pm
Prob something like 4 or 5 in the front and level it off in the back. My plans is to keep it blue and white. I will prob Paint the wheels white for now till I get it Rollin. Parts list to come...... I have the pancake engine that was in parts and pieces that was in side the bus I am going to sale as well a front and back bumper just like the ones on the bus. I plan to clean it Monday or Tuesday more pc to come.
Last edited by 67vdub on Fri May 04, 2012 7:32 pm; edited 1 time in total (Reason for editing : ?)
Post by 67vdub on Tue May 08, 2012 12:24 am
72 Bay Bus 133640515702172 Bay Bus 133640515437572 Bay Bus 133640515934472 Bay Bus 133640523613172 Bay Bus 133640528731872 Bay Bus 133640535761872 Bay Bus 133640535521872 Bay Bus 2012-05-06_20-11-02_61872 Bay Bus 1336405284669-172 Bay Bus 133640516158172 Bay Bus 2012-05-06_19-11-04_254
Daddy little helper for the big clean......It's looking better....I still have a lot to due.
Post by rpm750 on Tue May 08, 2012 6:56 am
I've never understood why folks leave primer uncovered like that. Primer is open pigment and the moisture goes right to the metal. Remove that primer and buy some rattle can spray the color of the bus and cover those areas. The primer isn't doing anything but hidding the brown spot!
Nice and solid, clean it up fix the little stuff and drive the crap out of it!!
Nice find.
Post by 67vdub on Tue May 08, 2012 11:23 am
This stuff works going to try to get off all of the primer off with it. I looked for a long time for a good start on a bay that was in my price range.
72 Bay Bus Spray_Paint_Graffiti
Post by 67vdub on Fri Jun 22, 2012 6:11 pm
Maybe one day I will get a min to work on the Bay..........Maybe one day.
Post by 67vdub on Tue Sep 25, 2012 6:19 pm
With of the help from a Great Friend the BAY should be on the road in a few weeks.
Post by 67vdub on Mon Oct 29, 2012 9:19 pm
Almost on the road new tires and a lower job.... Here we go!
Post by 67vdub on Sat Nov 03, 2012 1:42 pm
Engine Installed...Check
Trans Installed....Check
Running....Check
New Battery....Check
Tires Next week.....
Almost...!
Post by 67vdub on Sat Nov 17, 2012 9:41 pm
Tires are on. Last min stuff. Doodle it will all me in your hands.
Then fix rust and interior.
Post by DOODLE BUGG on Sun Nov 18, 2012 5:55 pm
sounds good to me
Post by Jon65 on Sun Nov 18, 2012 6:05 pm
Seems like its gonna be one awesome bay. Smile
Post by 67vdub on Sun Nov 18, 2012 6:12 pm
I have had 3 bays this one I am going to keep and get it right new trans and engine and a Doodle Lower job. I will be good.
Post by 67vdub on Thu Jan 24, 2013 10:26 pm
Well one more day of working but not able to get to my bus soon it will be done.Then lower job by Doodle.
Post by LB Bedwell on Fri Jan 25, 2013 9:15 am
good luck man I know it seems endless but you'll roll soon
LB Bedwell
LB Bedwell
Number of posts : 540
Post by DOODLE BUGG on Sat Jan 26, 2013 8:20 am
67vdub wrote:Well one more day of working but not able to get to my bus soon it will be done.Then lower job by Doodle.
give me a call when you get ready
Post by 67vdub on Mon Apr 01, 2013 11:02 pm
Got to spend sometime on the bus working on wires ordered some parts hope to be on the roll soon...
Post by 67vdub on Thu May 09, 2013 12:12 am
72 Bay Bus Null
Its HOME Still a lot to do...! BUT ITS HOME and I drove IT. cheers
