My 1969 Bug restoration
Post by vdubbers on Tue Feb 07, 2012 9:53 pm
Hey guys, my name is Chris and this is my build thread for my beetle. Early last year, I bought this bug from a fellow member on here. I found it through a friend on one of my Reef club forums that I am apart of. My original plan for the bug was to drop a 13b rotary engine in it.. After much thought, I decided that for a considerable amount less, I could have just as much fun. I also thought the car would be more drivable , daily. I now plan on putting a AS-41 Case with 92mm jugs, Progressive weber, 8 dowel fly wheel, etc...
When I bought the engine case, I also picked up a rag top. The seats are going to be replaced with seats from a 1983 Porsche 944. I had to modify the stock seat frames for them to sit flat on top. I took the bottom part of the Vw seat off the seat frame(never liked the springs). I then cut the tabs of the frame and cut the seat positioner " hook" thing off. At this point the new seats could be welded to the frame. The seats will be recovered in cloth. This will only be a two seater .... I say that but, I will probably get a back seat recovered, so if I wanted to have it I could. The interior will be all black. I hope to also find a wood grain steering wheel. I will have heat and sound deadening material all through it. Sounds system will have Two 6x9 in the rear and two 5x4 in the front and a 10 inch sub in the back.
Anyway that is all for now.. can't tell all my plans now haha.
Some pics of the progress
Chris C
vdubbers
Number of posts : 59
Registration date : 2012-02-02
Re: My 1969 Bug restoration
Post by buggin70 on Tue Feb 07, 2012 11:07 pm
you almost got it lol change the end tag to match the tag in front
Post by vdubbers on Wed Feb 08, 2012 12:18 am
i played with that for like 20 mins. But I did what you said and now i don't see anything ...lol
vdubbers
Post by callahan on Wed Feb 08, 2012 7:54 am
the end tag has to be [/img]
Number of posts : 1271
Post by fluxcap on Wed Feb 08, 2012 8:34 am
You need to find the correct url for the pictures that aren't working. One is working and you can see the url you copied/pasted below.
Code:
[img]http://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc6/270470_2229171846363_1159836831_32708986_7091648_n.jpg[/img]
See how the one above ends in .jpg. All the others end in "theater". Those won't work.
Code:
[img]http://www.facebook.com/photo.php?fbid=2229172126370&set=a.2229161846113.2133523.1159836831&type=3&theater[img]
And yes, once you get the correct url, make sure you end it with [/img]
Number of posts : 3856
Post by Attorney Isaiah Loophole on Wed Feb 08, 2012 4:23 pm
I was the one that fixed the one to get it working.....you need the exact address of the picture not the page address it is on...
Number of posts : 4949
Post by vdubbers on Wed Feb 08, 2012 5:41 pm
GOT IT lol
vdubbers
Post by vdubbers on Thu Feb 09, 2012 8:05 am
Currently I am taking the transaxle and swing arms off. Then it will be time to media blast it , paint it, and then re-assemble.
Chris c
vdubbers
Post by Grifspop on Thu Feb 09, 2012 11:41 am
What year is the X-19 next to it?
Post by vdubbers on Thu Feb 09, 2012 5:40 pm
1987......bertone really .......but x1/9 yes haha
vdubbers
Post by vdubbers on Tue Aug 21, 2012 12:59 pm
Bug is now sandblasted and ready for paint and body!
Rust free!
Drivers side damage..
Passenger side damage...
This will be replaced with a new quarter pan
Not sure what happened here
The worst of the rust repair
vdubbers
Post by vw57drvr on Tue Aug 21, 2012 3:27 pm
You may already know this, but that decklid is wrong for a 69.
Post by vdubbers on Tue Aug 21, 2012 4:00 pm
vw57drvr wrote:You may already know this, but that decklid is wrong for a 69.
Yes, I plan getting one with-out louvers.
vdubbers
Post by Grifspop on Tue Aug 21, 2012 5:30 pm
The hole in the tunnel usually indicates that the clutch cable tube has broken loose, and someone's welded it back in
Post by vdubbers on Tue Aug 21, 2012 8:09 pm
Grifspop wrote:The hole in the tunnel usually indicates that the clutch cable tube has broken loose, and someone's welded it back in
That's right, I remember someone telling me this before.
vdubbers
Post by vdubbers on Wed Nov 14, 2012 12:18 pm
Could someone tell me if this is in fact a 69', and if my doors are right?
vdubbers
Post by Cave Man on Wed Nov 14, 2012 3:57 pm
Deck Lid is not a 69. other than that it looks correct to me. 69 should have only 2 slots or none. my 70 came with 2 sets of vents from the factory.
Cave Man
Cave Man
Number of posts : 333
Post by vdubbers on Tue Jun 03, 2014 10:44 am
Actually worked on the bug on sunday..lol it has been a little bit
vdubbers
Post by vdubbers on Mon Jun 09, 2014 8:19 pm
On the first page of pics, there is a pic of where the clutch cable tube was re-welded and the hole in the tunnel. Do I just close up the hole or leave it accessible?
Chris
vdubbers
Post by vw57drvr on Tue Jun 10, 2014 9:14 am
I would recommend closing it. The tunnel is a vital piece of structure. Plus any open holes is just more sound to come through.
Post by vdubbers on Mon Jun 16, 2014 10:30 pm
But I laid some hot glue on the bug today. I am just starting to weld..never really done it just know the concept of it.Have not really learned how to do it professionally yet.
vdubbers
Post by Murdock00 on Sun Jun 22, 2014 12:29 am
Good work bud, looks like it will go together well at the end.
Murdock00
Number of posts : 53
Registration date : 2013-05-22
Post by DOODLE BUGG on Sun Jun 22, 2014 5:54 pm
Looking good man I'm trying to make time to work on some of my project but not enough time
Post by vdubbers on Sun Jun 22, 2014 9:24 pm
I think I did ok on the welding...or tacking.. not "really welding" I guess. I have never welded anything before just know the concept,watched a few youtube videos and have a little not so common sense. The only way to learn is by doing it
Chris
vdubbers
