Rear Hatch Glass
Rear Hatch Glass
I'm not wanting to hook up and use the rear window defogger, so is there a way to remove the heat traces or what split rear window will fit an early Bay rear hatch?
Re: Rear Hatch Glass
You can't just get one cut. ??
- Number of posts : 1416
Have you tried scraping with a razor blade? usually takes em off when you strip tint!!
- Number of posts : 798
No and No. It was late last night and I just got to thinking about it. I did walk out to the shop and look and yes it is not between the glass sections it is on the surface so I will try a mechanical method to remove it. I'm sure it's toast so why have it on there.
I think the hatch is interchangeable with a 66-67 so the glass may be as well.
bumblebuggy wrote:I think the hatch is interchangeable with a 66-67 so the glass may be as well.
That's what I was thinking too.....
I'm pretty sure the glass size didn't change.
» Bus Rear Hatch Spring/Hinge Removal
» 72 bay 2276
» Glass Question
» Lowering the rear
» Rear Lugs?!?!?!?!!!!!!!!!!
» 72 bay 2276
» Glass Question
» Lowering the rear
