53 Zwitter (Calvin)
Page 3 of 3 Previous  1, 2, 3
Re: 53 Zwitter (Calvin)
Post by Jon65 on Tue Apr 22, 2014 10:03 pm
Looks great! I like the pulleys that you chose.
Post by mrfeather on Wed Apr 30, 2014 2:09 pm
Looking good. Who makes the pulley set up.
mrfeather
Number of posts : 176
Post by sploval53 on Wed Apr 30, 2014 10:35 pm
It looks like a mst
Number of posts : 1416
Post by mrfeather on Wed Apr 30, 2014 10:38 pm
Cool thanks I have to check it out. I have a Berg but like the looks of this one.
mrfeather
Post by Raggtop on Thu May 01, 2014 11:37 am
Yes it's a MST set up.
Raggtop
Number of posts : 422
Registration date : 2010-12-30
View user profile http://dkk-savannah.blogspot.com/
Post by Raggtop on Wed Aug 27, 2014 11:42 am
I have been doing things a bit slowly lately, but still going..
Prepping engine bay and complete underside of body for KBS Coating Rust Seal Paint
Raggtop
Post by Raggtop on Wed Aug 27, 2014 11:52 am
Underside and wheel wells painted. decided to hit the luggage area also.....
Raggtop
Post by Raggtop on Wed Aug 27, 2014 11:55 am
A bit of Smoothing out!  Twisted Evil
Raggtop
Post by Raggtop on Wed Aug 27, 2014 11:57 am
Hoping to get some more done this weekend.. Shouldn't be much longer before its mounted back to chassis.. cheers cheers WooHoo
Raggtop
Post by Attorney Isaiah Loophole on Wed Aug 27, 2014 1:52 pm
Nice! Keep the progress and pictures coming!
Number of posts : 4932
Post by Raggtop on Wed Aug 27, 2014 10:05 pm
Thx Bryce.
Worked on the dash a bit tonight, think I got
It just right.
Raggtop
Post by Raggtop on Fri Sep 12, 2014 8:51 am
Prepping (taping) body for the spray in bed liner coating..
Raggtop
Post by Raggtop on Fri Sep 12, 2014 9:05 am
Almost everything your not going to see is sprayed with Liner Extreme spray liner. looks good.
very happy with it..
Raggtop
Post by Raggtop on Fri Sep 12, 2014 9:17 am
After tape and paper removal, decided to install engine seal and mount body back to chassis..
Raggtop
Post by type4revolution on Fri Sep 12, 2014 10:47 am
? You running caster shims behind that lower front beam tube. Just asking cause I believe I covered that in the class but not sure.
Number of posts : 907
Post by Raggtop on Fri Sep 12, 2014 11:17 am
You did but wasn't 100% sure on my application
Because of the air suspension.
Raggtop
Post by type4revolution on Fri Sep 12, 2014 11:29 am
Use them helps at higher speeds
Post by bakertim2 on Fri Sep 12, 2014 12:32 pm
Agreed. I use them on all lowered beams.
Number of posts : 3225
Post by Raggtop on Fri Sep 12, 2014 1:23 pm
10-4
Raggtop
Post by Attorney Isaiah Loophole on Fri Sep 12, 2014 8:36 pm
I like that liners texture. I am thinking about spray lining Pat's pan.
Post by Raggtop on Sat Mar 14, 2015 11:01 am
Body was on and drove the split a few times to find any problems, and i found one major one.
bag mount design and pipe size not strong enough for my application. will be coming off and re engineering
rear set up..
Raggtop
Post by Raggtop on Sat Mar 14, 2015 11:09 am
So started cutting out the old bar set up to get ready for new stuff.
Raggtop
Post by Raggtop on Sat Apr 11, 2015 9:36 am
Decided to move the lower bag mounts out towards the wheels about 2 inches, should help with lift issues and I'm sure it will create other ones. Both sides done time for paint and to start on the uppers situation
Raggtop
Post by Raggtop on Sat Apr 11, 2015 9:42 am
Cut old Cross bar out to get ready for new larger pipe
Raggtop
