53 Zwitter (Calvin)
+14
earlyvwfanatic
bulldawgdude
kokodabobo
hly3rd
SavannahVW
Raggtop
18 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: 53 Zwitter (Calvin)
Thanks Bryce...Attorney Isaiah Loophole wrote:Looking very nice! That powder coating is just sweet!
Got tranny bolted up and threw in the Motor. Needed to check clearence of sump and muffler. Looks like sump is clear but muffler has a clearence issue. But may be able to fix the situation.
Aw yeah. Coming together very nicely!
Jon65- Complete Dub Addict
- Number of posts : 875
is that as low as it goes? not wanting to lay pan? or is the 17s holding it up?
- Number of posts : 1956
That is as low as it goes. The 17's are keeping it up. If I was running 15's I would be Negative height. Lol.
Put the body back on for air sys check and sensor placement. Also wanted to see if this bus muffler would work on the car. And looks like a winner to me ! Think I will run it.
Very nice.
Thx Kyle
I have a sump on the motor and its sitting on the ground now. I want it nice and low without destroying it. If the deep sump ends up being to low may go with a thin one.
Borrowed a front Fender from Tim to check clearance of height sensor movement to headlight bucket. so far so Good.
also got my rendering of my car done, thanks to KP Concepts for a awesome job. Hoping the rendering to Reality looks the same, i know its not going to be that low but would be Sweet!
bulldawgdude- Dub Nut
- Number of posts : 269
Registration date : 2011-03-30
Looks great.
Are you doing one piece window?
earlyvwfanatic- Dub Nut
- Number of posts : 307
Things have slowed down a bit for Holidays. but will pick it back up right after.
Will be looking for a good paint and Body Man also.
Thats the plan..earlyvwfanatic wrote:Are you doing one piece window?
Looking good
mrfeather- Dub Nut
- Number of posts : 176
If the sump dosent work ouk you could go with a oil reserve tank
mrfeather- Dub Nut
Sounds like that would work. Where/ who carries them? Would love to see the set up.
A lot of option out there these is a good search link allows you many choices. I hope this helps you might also check out http://www.geneberg.com/
https://www.google.com/search?q=external+oil+reservoir+tank&num=40&safe=off&espvd=210&es_sm=122&source=lnms&tbm=shop&sa=X&ei=2cepUtmIAcTpkQe6iIEY&ved=0CAsQ_AUoAw&biw=1277&bih=712
mrfeather- Dub Nut
What's the latest and greatest on this?
Got my Alt in and installed. Along with a new starter.
Motor all together and running.
Have filled in trim holes on drivers body side, now to
Finish the pass side. Will get some pics today.
What dizzy is that?
ridikas- Dub Nut
- Number of posts : 377
I'm digging all the black bits. Looks really good Scott!
Page 2 of 3
