rubber cam plug leaking ?
rubber cam plug leaking ?  Empty rubber cam plug leaking ?
Post by type4revolution on Sun Dec 25, 2011 11:03 pm
Does your rubber cam plug leak or pop out I have got the fix if your case is not cut for steel cam plug on late model cases let me know if your interested pics coming soon
Number of posts : 907
rubber cam plug leaking ?  Empty Re: rubber cam plug leaking ?
Post by type4revolution on Mon Dec 26, 2011 2:19 pm
rubber cam plug leaking ?  Resampled_2011-11-26_11-42-38_204 does your rubber cam plug look like this or leaking well seal it up like this
Last edited by type4revolution on Mon Dec 26, 2011 2:48 pm; edited 2 times in total
Post by type4revolution on Mon Dec 26, 2011 2:26 pm
rubber cam plug leaking ?  Resampled_2011-12-23_12-16-49_507make a plate .050 thick and drill it out like pic. use 8-32 screws drill and tap case around cam plug hole like this, be very careful metal here is thin and no room for error don't drill to deep 1/4 inch deep is good
Last edited by type4revolution on Mon Dec 26, 2011 2:53 pm; edited 3 times in total
Post by type4revolution on Mon Dec 26, 2011 2:30 pm
rubber cam plug leaking ?  Resampled_2011-12-23_12-24-39_724
Post by type4revolution on Mon Dec 26, 2011 2:35 pm
rubber cam plug leaking ?  Resampled_2011-12-23_14-42-58_990 when your done clean area well install new rubber cam plug don't get crazy with the sealent here I use dirko for this application then put some on plate and install
Post by type4revolution on Mon Dec 26, 2011 2:45 pm
rubber cam plug leaking ?  Resampled_2011-12-23_14-57-28_807. Tighten screws but don't overtighten then use a lite amount of seatent on cover plate and screws and ur done no more leak or blown rubber cam plug. Another one of vws piss poor choices to not machine cam plug groove. If you can avoid it don't buy a case like this with rubber cam plug steel rules
