carb adjustment 30/31 pict
carb adjustment 30/31 pict Empty carb adjustment 30/31 pict
Post by buggin70 on Wed Jun 22, 2011 4:56 pm
what do you guys do?
i was told a few diff ways how to do it
i feel like my car has no power anymore
i adjusted the points and it got a little better
carb adjustment 30/31 pict Empty Re: carb adjustment 30/31 pict
Post by Bugman114 on Wed Jun 22, 2011 6:02 pm
i forget if its the same as a 34 but if it is:
first take the airfilter off. rev it up, and stick your hand over the carb to suck out any crap that might be in it. then adjust the small mixture screw till you get it right. the big screw adjusts the idle, so you;ll have to play with both till its just right. turn the little one in till it starts to die, then slowly back it out just till it seems to get better. then take it for a ride, and see how it performs. if it still runs rough, back it out a tad more. and take it for another ride. keep going till it runs good. only back it out by 1/4 turn at a time, and then drive it. this is how i learned initially.
if turnng the small screw doesn't seem to make the motor change while idling, then there IS something else wrong (clogged jets, passage ways clogged, etc.).
might also wanna throw a can of sea-foam in the tank as well. i love that stuff.
Post by vw57drvr on Fri Jul 01, 2011 4:25 pm
Post by Grifspop on Fri Jul 01, 2011 4:57 pm
Great video!
