Traditional question, anyone have a decent DIY for narrowing a beam
Page 2 of 2 Previous  1, 2
Traditional question, anyone have a decent DIY for narrowing a beam - Page 2 Empty Re: Traditional question, anyone have a decent DIY for narrowing a beam
Post by Grifspop on Wed Jun 08, 2011 5:29 pm
fluxcap wrote:I think it has to do with the fact that on a stock beam, the center is of the leafpack is held stationary by the grub screw. The center of the pack never flexes and stays stiff. The further from the center you move, the more the leaf pack twists and weakens over time. Therefore if you cut the same amount off of each end, the flex/wear on each end will be the same. If you only cut one side, the uncut side would probably be weaker and sit a little lower. The side you cut will be closer to the original center of the leaves and probably be a little bit stronger.
Exactly!!
Post by rpm750 on Wed Jun 08, 2011 10:03 pm
You got it Flux but....
.....you have got to move it back to the center. The adjuster wouldn't be off to the side, it will be in the middle. Thus the same twist, flex call it what ya want the adjuster will need to be in the middle, if it is it should be balanced. Basically where ya cut the slot and weld the adjuster bracket is the new center of the beam.
Post by 86vwgti8v on Wed Jun 08, 2011 10:14 pm
fluxcap wrote:
86vwgti8v wrote:Makes sense...
Nice job on your beam!
Thank you!
86vwgti8v
86vwgti8v
Number of posts : 317
Post by Grifspop on Wed Jun 08, 2011 10:16 pm
Thank you!
X2!
Post by Attorney Isaiah Loophole on Wed Jun 08, 2011 10:46 pm
rpm750 wrote:You got it Flux but....
yes everything gets centered but the wear on the leaf pack is now not the same from side to side...
Number of posts : 4962
Post by rpm750 on Thu Jun 09, 2011 6:51 am
Thank you!
X2!
X3!
How narrow did ya go?
Post by 86vwgti8v on Thu Jun 09, 2011 7:37 am
6"
86vwgti8v
86vwgti8v
Post by rpm750 on Thu Jun 09, 2011 8:47 am
Wow that's narrow, mine is 4" and I want to build another one using shocks, it's a rough ride without them.
Post by 86vwgti8v on Thu Jun 09, 2011 8:50 am
I replaced the top and bottom leafs, the ones that are split with 2 solids in each tube. All my leafs are one peice, hoping that helps a little.
86vwgti8v
86vwgti8v
Post by 86vwgti8v on Thu Jun 09, 2011 9:44 am
Traditional question, anyone have a decent DIY for narrowing a beam - Page 2 2011-06-09_08-52-06_514
Traditional question, anyone have a decent DIY for narrowing a beam - Page 2 2011-06-09_08-52-23_398
Done!
Some advice, to get the leafs back in easier, clamp them tack the ends, grind a chamfer on all four sides then tap.
Traditional question, anyone have a decent DIY for narrowing a beam - Page 2 2011-06-09_06-08-55_458
After its in, mark it and cut it. So much easier
86vwgti8v
86vwgti8v
