coil shorting out
coil shorting out
Post by zabo on Tue May 24, 2011 9:26 pm
little cross post from the samba but...
So i replaced my generator with a used one hooked everything back up and the car would not start.
Messed around a bit and found if i unscrewed the coil from the shroud and just let it hang the car starts right up. (red lights on tho)
If i ground the coil bracket the car dies.
any ideas why it would be shorting out like this?
thanks
Re: coil shorting out
Post by Bugman114 on Tue May 24, 2011 11:03 pm
have you tried a new coil? I'm guesing the negative on the coil itself is touching the body of the coil (either inside or out) which in turn is grounding on the shroud. the paint on the coil must have rubbed off, making contact with the bracket.
Number of posts : 2460
Post by zabo on Thu May 26, 2011 4:24 pm
yep it was the coil, i guess the inside of the coil was touching the case somehow causing it to short out when connected to the shroud.
Post by Grifspop on Thu May 26, 2011 9:17 pm
zabo wrote:yep it was the coil, i guess the inside of the coil was touching the case somehow causing it to short out when connected to the shroud.
Does the generator still need to be swapped out?
Post by zabo on Thu May 26, 2011 10:54 pm
Nope
Had to swap out the regulator tho
Post by Grifspop on Thu May 26, 2011 11:14 pm
zabo wrote:Nope
Glad you got the mighty 6 volt system working like it should Very Happy Very Happy
