76 FI issues
76 FI issues
Post by PeeWeeMan91 on Wed Apr 20, 2011 8:17 am
when its started in the morning it will not hold its own. i have to keep my foot on the gas till it warms up. and if i dont let it warm up i jumps and studders. whats wrong?
PeeWeeMan91
Number of posts : 567
Re: 76 FI issues
Post by peregrine67 on Wed Apr 20, 2011 9:32 am
I had a simlar problem. Check all your vacum hoses, particularly the one that goes to the pressure regulator. I reattached that and it fixed about 90% of the problem. Then I just set the idle a little bit higher and that fixed the rest.
Number of posts : 1343
Re: 76 FI issues
Post by PeeWeeMan91 on Wed Apr 20, 2011 10:01 am
what pressure regulator the fuel?
PeeWeeMan91
Re: 76 FI issues
Post by peregrine67 on Wed Apr 20, 2011 10:37 am
My experience with FI is on a T4 engine but I think the FI is relatively the same.
Follow the fuel line and rail from the fuel pump past all the injectors and then back to the tank. Before it leaves the engine compartment there should be a pressure regulator that has a vacum hose attached. My vacum line connector had dry rotted and I had to replace it.
Re: 76 FI issues
Post by meinvw on Thu Apr 21, 2011 6:19 am
Could be your cold start valve or check the connections to the afm. Vaccum hoses could be a culprit but if it clears up when warm I would check the others.
meinvw
Number of posts : 894
Re: 76 FI issues
