My 65 Beetle Leela
Page 9 of 10 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
My 65 Beetle Leela - Page 9 Empty Re: My 65 Beetle Leela
Post by Damn-it Don on Sun Oct 30, 2011 10:11 am
Got a link to the bucket?
Post by 86vwgti8v on Sun Oct 30, 2011 10:16 am
Kip, she said the pics should be fine to blow up, I'll make you a disc and mail it.
I'll get a link to the bucket when I get home, or trace it through the url in the posted pics.
86vwgti8v
86vwgti8v
Number of posts : 317
Post by Grifspop on Sun Oct 30, 2011 10:40 am
Great pics!!
Post by Attorney Isaiah Loophole on Mon Oct 31, 2011 12:33 pm
Grifspop wrote:Great pics!!
x2
Post by vwkultur on Mon Oct 31, 2011 9:41 pm
x2
X3
vwkultur
vwkultur
Number of posts : 409
Post by 86vwgti8v on Tue Nov 01, 2011 4:46 am
3x thanks!
86vwgti8v
86vwgti8v
Post by vwovalchild on Tue Nov 01, 2011 6:26 am
X4 nice angles
Number of posts : 895
Post by 86vwgti8v on Tue Nov 01, 2011 6:29 am
Thank you, that was my girlfriend. She is great with her camera.
86vwgti8v
86vwgti8v
Post by loves trim on Tue Nov 01, 2011 7:37 am
Hey sam, i picked up a 67 beetle last night. The guy was from your area.
loves trim
Number of posts : 258
Post by 86vwgti8v on Tue Nov 01, 2011 7:39 am
Who was it? What color?
86vwgti8v
86vwgti8v
Post by loves trim on Tue Nov 01, 2011 8:43 am
The blue one on greenville craigslist. It was not as straight as what i was told but it will work.
loves trim
Post by 86vwgti8v on Tue Nov 01, 2011 8:44 am
Does it run? Plans for it?
86vwgti8v
86vwgti8v
Post by loves trim on Tue Nov 01, 2011 8:59 am
Runs good. He drove it from s.c. to mall of ga and i drove it home. It has a lot of low end power. Im going to dump it and i think im going flat tan or flat brown. It was hit in the right side and the repair is shotty. Im going to cut the rocker/heater channel out repull the door post and replace the channel. Its got a little rust but not bad.
loves trim
Post by 86vwgti8v on Wed Nov 16, 2011 8:35 pm
Started on a 1641. line bored, case savers, the heads are in the machine shop. all the tins have been media blasted. its getting a Engle 100 cam
My 65 Beetle Leela - Page 9 Ade5e776
My 65 Beetle Leela - Page 9 Badef74b
86vwgti8v
86vwgti8v
Post by callahan on Wed Nov 16, 2011 8:49 pm
think about getting a doghouse oil cooler set up while you're at it
Number of posts : 1271
Post by buggin70 on Wed Nov 16, 2011 8:50 pm
callahan wrote:think about getting a doghouse oil cooler set up while you're at it
get the doghouse 36 horse style shroud
Post by 86vwgti8v on Wed Nov 16, 2011 8:56 pm
this is getting over my head now.
what is the signifigance of the 36 hp shroud?
what is the doghouse oil cooler? If I am understanding things correctly it will be mounted inside the doghouse.
86vwgti8v
86vwgti8v
Post by buggin70 on Wed Nov 16, 2011 9:03 pm
A doghouse cooler is offset so all the hot air dosnt go right over the 3rd cylinder and I just like the look of the early shrouds
Post by callahan on Wed Nov 16, 2011 9:13 pm
yep a doghouse style cooler is just more efficient and all that jazz. it just makes sense to swap to one if you're building a new engine i just did the same thing and put a doghouse set up on mine. and yes a 36er shroud is just an aesthetic thing
Post by bakertim2 on Wed Nov 16, 2011 9:23 pm
My 65 Beetle Leela - Page 9 845357
Above is a doghouse style fanshroud
My 65 Beetle Leela - Page 9 507880
above is a doghouse cooler if you look at it you can see that it's set back to allow more air to flow over the cylinders without getting heated up after going through the oil cooler.
My 65 Beetle Leela - Page 9 608487
above is a 36 horse style shroud
Post by 86vwgti8v on Wed Nov 16, 2011 9:25 pm
No heat with that shroud?
86vwgti8v
86vwgti8v
Post by bakertim2 on Wed Nov 16, 2011 9:27 pm
You can get it with or without
Post by Bugman114 on Wed Nov 16, 2011 9:37 pm
an aftermarket 36 shroud has far less cooling, and no provision for flaps. i've had 2 motors with 36hp shrouds, and on both motors, they always ran a lot warmer, then when i put a stock shroud on it. if you drive your dub everyday, then i'd go with a stock shroud. if its just a weekend warrior, then the 36er shroud does look a lot nicer.
It also has no provisions for flaps. even if you don't have a thermostat u should still have a set of flaps wired open, as the flaps help direct air towrds the heads. Also don't forget the hoover bit either Wink .
Post by 86vwgti8v on Thu Nov 17, 2011 8:06 pm
Some more goodies!!
My 65 Beetle Leela - Page 9 B4da9ec6
My 65 Beetle Leela - Page 9 E6c61d67
My 65 Beetle Leela - Page 9 4b8f7ce9
Fogs, og stingray, and lighter!
86vwgti8v
86vwgti8v
Post by earlyvwfanatic on Thu Nov 17, 2011 8:37 pm
86vwgti8v wrote:Some more goodies!!
Where did you pick up the foglights from?
earlyvwfanatic
earlyvwfanatic
Number of posts : 307
