pre heater help
pre heater help
I have been iceing over so i pulled my intake to find the preheater clogged i have tried to run a hanger chucked up in a drill with no avail it keeps breaking off so now its soaking in carb cleaner help....
Whit
Whit
jamrens- Dub Noob
- Number of posts : 99
Registration date : 2011-02-26
Re: pre heater help
carb cleaner should get it also make sure the flange in the header is not blocked off
Re: pre heater help
coat hanger probably won't work. I've always had luck with a braided wire. Last time I used an old e-brake cable. Frayed the ends just slightly, and put it in the drill. If you are using a long cable, it'll be a little hard to get started, but once it gets going, it works great.
Find a thick braided wire (e-brake cable, clutch cable, etc...) and give that a try.
Re: pre heater help
i finally got it went to ace and got some 1/4 in braided cable and a bottle of liquid plumber worked wonders...
jamrens- Dub Noob
Re: pre heater help
Nice, I need to do that to the Jap Beetle...jamrens wrote:i finally got it went to ace and got some 1/4 in braided cable and a bottle of liquid plumber worked wonders...
Re: pre heater help
bro its a bitch.. honestly if i whould have known that i could get a bnib intake from foreign American auto parts in dalton for 40 i whould have just got a new one..
jamrens- Dub Noob
Re: pre heater help
Haha, I've felt that way too after cleaning a tough one. Good news is that now that you've done it, if you need to do it again in a few years, it won't be that bad. You'll only be fighting 2-3 years of build up versus the probably 10-20 years that you just fought through.
» Heater box question?
» Headlight question an heater ???
» Heater Channel Question.
» Type 1 Heater Boxes
» welding up heater boxes
