Dropped Spindles
Dropped Spindles
Post by BKiller on Fri Jan 14, 2011 8:17 pm
So I understand what dropped spindles do from my mini-truckin days. Is there any reason not to run them on a VW? Seems like they are out there but not that popular?
Don't they allow more suspension travel then adjusting the beam?
Number of posts : 687
Re: Dropped Spindles
Post by Attorney Isaiah Loophole on Fri Jan 14, 2011 8:29 pm
Yeah they do...much softer ride at the same or lower height....could be a good thing or a bad thing
On a side note have you seen the type 3 dropped spindles for like $7-800.....wow
Number of posts : 4949
Post by bakertim2 on Fri Jan 14, 2011 9:14 pm
I like the use of spindles. It gets you that much closer to the ground. But, on lp front end it is pricey to get them set up. For example, you can purchase the spindles for around 100 bucks then kp and lp cost another 80 bucks then having them pressed is another 100 bucks.
Number of posts : 3229
Post by Rusty62 on Sun Jan 16, 2011 5:16 am
I have a set of ball joint drop spindles for sale. Smile
Rusty62
Rusty62
Number of posts : 105
Registration date : 2009-02-26
Post by bakertim2 on Sun Jan 16, 2011 8:05 am
That wouldn't be the ones we took back off your car, Would it?
Post by Rusty62 on Sun Jan 16, 2011 8:36 am
Shoot I messed up. They are for a later link pin, but yeah those are the ones.
Rusty62
Rusty62
Post by Muffler Bearing on Sun Jan 16, 2011 10:36 pm
I run the 2.5" CB performance spindles on my 66 and I would not have it any other way. Ride did not change at all. I think I paid $125ish for them. then had to change the inner seals and tie rod ends. Think it was about $200-$225 after it was all said and done. check out b4 and after pics in my pics page "My 66 beetle" if you want.
Number of posts : 731
