Electronic Speedometer
Electronic Speedometer Empty Electronic Speedometer
Post by EngineerTEN on Sun Jan 02, 2011 6:35 pm
Does anyone have any experience replacing an original speedo with an electronic speedo? If so, how did you get it to fit the stock opening?
Jason
Number of posts : 358
Electronic Speedometer Empty Re: Electronic Speedometer
Post by EngineerTEN on Thu Jan 06, 2011 1:59 pm
I couldn't find any useful info on The Samba. Guess no one on here knows either. Still thinkiing about doing it with an electronic speedometer kit from CB Performance. http://www.cbperformance.com/catalog.asp?ProductID=1205
Then also installing matching gauges in the steering column pod I got from Air Kewled.
Post by vwtattooed on Thu Jan 06, 2011 2:19 pm
you will need to make a panel that will attach to the dash from the backside,out of metal,plastic or wood. cut a hole the diameter of your gauge(most come with a template)paint or cover the panel and attach it to the dash with the 2 studs the factory used or permanately with 2 part epoxy glued to the dash. you will need a speed sensor compatible with the gauge (pulses per minute) and wire the gauge per the instructions. more than likely you will need a setup that will attach to the axle shafts and will need to fab up a bracket to hold the reciever. it can be done, i have done it. i used cyberdyne gauges and a rostra sending unit.
Number of posts : 798
Post by ASBug on Thu Jan 06, 2011 4:36 pm
I remember seeing that CIP1 had an adaptor that attached to a new shorter Speedo cable? that would then work the electric VDO guages.
I get CIP1 and GoWesty emails and it was on one of their pages...
Just check under new products....
Post by EngineerTEN on Thu Jan 06, 2011 6:11 pm
Thanks! CB Performance has the electronic sender adapter for the stock speedo cable as part of the kit or they sell it by itself for $78. The mounting is the most tricky. I was thinking about having an adapter machined to fit the current dash opening and that would accept an aftermarket gauge. I was thinking about maybe an aluminum plate that is polished.
How does the electronic Auto Meter or VDO gauges mount to a surface? I have not been able to find any photos of anything but the face.
Post by vwtattooed on Thu Jan 06, 2011 7:33 pm
both mount from the front,they slide into the hole and are held in place with a spreader bar from the backside. some of the VDO gauges use a plastic "nut" that threads onto the gauge housing,either way they both just sandwich your panel. i remember seeing the CB kit, just verify the pulse width matches the gauge you are looking at.
