i have 2 problems
i have 2 problems
well to start im pretty sure my clutch is slipping really bad i just want yalls opinions
rpms really high (sound high i dont have a tach) and i go nowhere
and it wont do up a hill i have to downshift to third when before i didnt
and just a all around loss of power
problem two is i think my rear shocks need to be replaced
what kind should i get?
currently im lowered 2 outer clicks
- Number of posts : 1956
Re: i have 2 problems
and would my flywheel have to be reserfaced or get a new one also?
No, we just have jobs and have to go to bed early . If you are still able to drive, I don't guess it's going to be a stripped brake drum, so it does sound like something clutch related. Are you dripping any oil possibly from around where the engine and transmission mate up? Could be your main seal or transmission is leaking and getting the clutch area slippery. Or your pressure plate may have weakened. I'm no expert on this issue, so let others chime in first, but you'll probably need to pull the engine and take a look at everything to find the problem.buggin70 wrote:um guess everyone hates me and they dont wanna help?
true i guess i never look at the tie when i dont have school.
i forgot to mention this clutch is maybe a year old if that
but i did have to push it off forever and ride the cluch when i didnt know how to fix my car and it ran real bad
ill look for the oil
and i only have to make it to school and back on monday
then i can tear it apart and i dont have school til december first so ill have time to fix it
but anyone else feel free to chime in
fluxcap wrote:No, we just have jobs and have to go to bed early . If you are still able to drive, I don't guess it's going to be a stripped brake drum, so it does sound like something clutch related. Are you dripping any oil possibly from around where the engine and transmission mate up? Could be your main seal or transmission is leaking and getting the clutch area slippery. Or your pressure plate may have weakened. I'm no expert on this issue, so let others chime in first, but you'll probably need to pull the engine and take a look at everything to find the problem.buggin70 wrote:um guess everyone hates me and they dont wanna help?
The possible culprits are pretty much in that same area- I'd pull the engine too, and see what you find. I pretty sure, when a brake drum gives out, it suddenly quits (you get an all than nothing kinda event) so i doubt it's that. All the stuff mentioned above would probably give the symptoms you have- so get out those jackstands!
i dont wanna sound spoiled but im going to use the lift
wayyyyyyyyyyyyyyyy easier
but i do know how to do it on jack stands too ive done it pleanty of times with drew
Check that your rear brake drum hub is not worn and spinning as well. I've had that happen to me.
EngineerTEN- Dub Nut
- Number of posts : 358
if the clutch is indeed slipping, you will need a new flywheel if you keep driving it, because if it wears all the way down to the rivets or the metal, your screwed. also, if you overheat it to bad, you will also need a new flywheel. but yeah, check for oil, if its oil'y replace the flywheel o ring and rear seal
i looked and there is no oil
ill go out in a second and look at the drums
and this sucks cause its my daily. i only drive it when i absolutely have to now
» 74 beetle idle problems
» ugh electrical problems!
» starter problems
» New motor build problems
» 79 baywindow electrical problems
» starter problems
