2nd gear question.
2nd gear question.
Post by fried_chicken on Sun Sep 26, 2010 7:07 pm
Ok when i shift to second it always wants to try to go to reverse and grinds i replaced the shift coupler a few days ago and it stopped doing that all was good, just today it came back. Will the front shifter bushing be causing this?
fried_chicken
Number of posts : 336
Re: 2nd gear question.
Post by buggin70 on Sun Sep 26, 2010 7:08 pm
get a reverse lock out
Post by Attorney Isaiah Loophole on Sun Sep 26, 2010 7:08 pm
yes the front bushing could be causing that or an incorrectly aligned shifter
Number of posts : 4926
Post by Attorney Isaiah Loophole on Sun Sep 26, 2010 7:10 pm
buggin70 wrote:get a reverse lock out
i have one in Jade and it still sometimes grinds when downshifting cause it is trying to go into reverse...but the shift bushing is shot in that car too
Post by buggin70 on Sun Sep 26, 2010 7:14 pm
mine hasnt ground bad yet (knock on wood) but my shifter isnt a year old yet
Post by Bugman114 on Sun Sep 26, 2010 8:58 pm
are you talking about the shift rod bushing thats a PITA to get to? my shifter is doing the exact same thing. i've gotten in the habit of while shifting into second, a hold it closer to the right, because if i hold it to the left while shifting into second, it will grind.
I just got my steering fixed, and was soo pleased at how tight the steering is, i want everything to be nice and tight now, lol.
Post by Attorney Isaiah Loophole on Sun Sep 26, 2010 9:00 pm
yes the bushing under the shifter
Post by 39coupe on Mon Sep 27, 2010 10:23 am
I had this problem with a scat shifter. I replaced the coupler at the rear of the shift rod, replaced the bushing in the tunnel at the shifter and also had to grind the screw holes on the shifter base to allow it to slide side to side a bit so that I could adjust the shifter position.
All has been working great for the past couple of weeks since doing all of this.
39coupe
Number of posts : 455
Post by fried_chicken on Mon Sep 27, 2010 8:32 pm
sweet thanks guys i will be heading to the parts place tomorrow to get one and hopefully fix it, cause sometimes its gets reallllly annoying .
fried_chicken
Post by vwkultur on Mon Sep 27, 2010 8:39 pm
Hint.............Listen to the old man! Laughing
vwkultur
Number of posts : 409
