fixing oil filler
fixing oil filler
Post by PeeWeeMan91 on Thu Sep 23, 2010 9:12 am
ok my oil filler is leaking around the joint of the top section and bottom so im thinking some jb weld and paint any objection?
PeeWeeMan91
Number of posts : 567
Re: fixing oil filler
Post by vwtattooed on Thu Sep 23, 2010 11:59 am
if you mean where the 2 pieces are joined..there is a gasket in there. you can remove the large filler part from the neck, there is a nut inside you'll need to remove. this requires a special tool. then you can replace the seals. if you wanna do it the easy way, then JB Weld should work provided you clean the area VERY good beforehand.
Number of posts : 798
Post by PeeWeeMan91 on Thu Sep 23, 2010 12:21 pm
i just replaced that one this is the big black pice that has the cap. there is a seam in the middle of it
PeeWeeMan91
