Still wobely
Still wobely Empty Still wobely
Post by daltondragger73 on Sat Oct 11, 2008 11:27 pm
Ok last time I was home I had to replace an axel and rear brake system. after putting everything together Its still loose the axel that is, the bearings are not bent everything went back together real good, The crown nut was tourqed to 250ftlbs and im lost on what could be making it still loose through the hub, Ill be home next weekend and I want to get it done so I can actually drive it any thoughts
Number of posts : 334
Still wobely Empty Re: Still wobely
Post by fried_chicken on Sat Oct 11, 2008 11:30 pm
maybe we torqued it too much and it put a bind on the bearing and broke it??? idea maybe.
fried_chicken
fried_chicken
Number of posts : 336
Post by daltondragger73 on Sat Oct 11, 2008 11:34 pm
it was still loose b4 we tourqed it
Post by fried_chicken on Sat Oct 11, 2008 11:36 pm
oh yeah thats right sorry, i had a brain fart. Cool
fried_chicken
fried_chicken
Post by daltondragger73 on Sat Oct 11, 2008 11:39 pm
lol! Whats new affraid
Post by fried_chicken on Sat Oct 11, 2008 11:42 pm
afro
fried_chicken
fried_chicken
Post by Clyde on Tue Oct 14, 2008 11:20 pm
Swingaxle or IRS?
Clyde
Clyde
Number of posts : 278
Post by daltondragger73 on Wed Oct 15, 2008 7:51 am
Its IRS I should be home fri and Im gonna tackel this, to see what it could be
Post by bumblebuggy on Wed Oct 15, 2008 8:08 am
First, go with the basics. Make sure the Lugs are tight and noe are stripped. Then pull the drum and lay it on the floor and make sure it isn't warped or bent. Check the splines on the stub axle and inside the drum. I would then take the drum and the wheel from the other side and mount it to the new side to make sure the problem stays on the same side. If it moves, you know it's the drum or the wheel.
Post by Clyde on Wed Oct 15, 2008 10:57 am
Is the play axial or radial? If it's in and out, while facing the tire, you might not have the bearing spacer that goes between the inner and outer bearings. Look at the axle nut, does one axle poke out of the nut more than the other?
Clyde
Clyde
Post by daltondragger73 on Thu Oct 16, 2008 2:49 am
I will check all that when I get home fri.. and post any more info that I can if I dont solve the issue... thanks guys!!!!!
