what is wrong with my car
+5
skunk
9 posters
my bug has lost power is runnin funny is missin and sounds like the fan is a leaf blower...could anybody tell me what might be the problem
Re: what is wrong with my car
please dont put curse words into ur heading or on the site!!! thanks chase
daltondragger73- Dub Nut
- Number of posts : 334
Please do not curse in our forums, did you check your plug wires, if one is not connected it will lose power and skip, about your fan, did you check the fan nut?
Cambur- Complete Dub Addict
- Number of posts : 910
Thank you for saying that. I couldn't wait till I got home and to my lap top to say something about that. There is a lot of other words one can use instead of the curse words !
I'm partial to poot, fiddle sticks, gosh, gee whiz, wow wee, man alive, darn it and fudge.
do you have points or EI, sounds like an ignition problem and your fan probably sucked something up stick your hand back there and feel around, make sure the engine is off first before you do that, it will take your fingers off .
59suicide- Dub Crazy
- Number of posts : 552
check your valve adjustment and also see if the belt is still tight.the belt could be old and be expanding when you rev the engine,making the fan shroud rattle.
tarvw- Dub Nut
- Number of posts : 228
With those symptoms sounds like the nut has come loose from the fan. Charging issues becasue of the fan loss might cause the missing.
Only other I can think of with noise and running crappy is you blew a plug out.
sounds like the same thing my 75 double cab did in NC at the highcountry bus festivle
it was my points and plugs
MainVW saved me that trip
Thanks again dude
Thanks again dude
- Number of posts : 1416
whats up dudes i posted this when i first made an account sorry for the cursin...i forgot all about postin this..naw it wasnt the plugs,or the fan nut,but it was my belt and the air filter on the carb. wasnt getin any air through it. but thanx yal
» whats wrong
» New Game - What's wrong with in this Picture?
» "Something is wrong with my car." The customer exclaimed.
