slinging oil
slinging oil  Empty slinging oil
Post by PeeWeeMan91 on Mon Jun 28, 2010 5:20 pm
um oil is all over the engine bay now and i cant tell if its leaking around the crankshaft pulley or the oil pump cover plate. what should i do
PeeWeeMan91
PeeWeeMan91
Number of posts : 567
slinging oil  Empty Re: slinging oil
Post by Bugman114 on Mon Jun 28, 2010 5:24 pm
get some brake cleaner, spray the engine down till its nice and clean, and start it up, and see if you can see any oil from anywhere. if not take it for a short ride around the block, and check again. you should be able to tell where its comming from.
Post by PeeWeeMan91 on Mon Jun 28, 2010 5:25 pm
well i went to the car wash yesterday and sprayed it all off and i still cant tell. can you tell me how to upload photos so i can show u what it looks like.
PeeWeeMan91
PeeWeeMan91
Post by Bugman114 on Mon Jun 28, 2010 5:43 pm
you have to first post them in a photo hosting page, like photobucket, and then link them here Via the link
for example:
[img]www.photobucket.com/Your_Album/Your_Picture.jpeg{/img]
the last "{" should be a "["
if you don't have a photobucket page, just email them to me, and i'll post them for ya
MVP114@charter.net
-Mike
Post by Bugman114 on Mon Jun 28, 2010 6:12 pm
Photo bucket is being buggy right now, so i'll post them up later, when its not acting up. but its kinda hard to tell from the pics, but is there also oil on the left side? if so it almost looks like blow by from the crank pulley. i doubt its from the oil pump cover, as the pulley tin would shield it. the under side of the motor would be covered in oil, but i wouldn't think the top would get any oil. i'd bet on the pulley. is that a stock pulley? if so, the vents on the motor might be clogged up. check the vent on the oil filler neck, assuming you still have the stock one. it should be routed to the airfilter somehow. if its plugged up, this is most likely your problem. also make sure your oil is at the correct level. too much oil can cause it to blow by the pulley as well.
Post by PeeWeeMan91 on Wed Jun 30, 2010 12:47 pm
I kinda stopped it. Took the pulley all the way off and re. Seated it. But it's still leaking. But not bad enough to drip on the floor but my tranny is giving me trouble now I think syncros are failing so I need a new tranny. I do alot of highway driving would it be worth it to get a five speed freeway flyer. Somebody tell me honest opinion
PeeWeeMan91
PeeWeeMan91
Post by 65type2dailydriver on Wed Jun 30, 2010 12:53 pm
PeeWeeMan91 wrote:I kinda stopped it. Took the pulley all the way off and re. Seated it. But it's still leaking. But not bad enough to drip on the floor but my tranny is giving me trouble now I think syncros are failing so I need a new tranny. I do alot of highway driving would it be worth it to get a five speed freeway flyer. Somebody tell me honest opinion
I would probably get a freeway flyer, but unless you are super rich a 5 speed tranny is alot of $$$$$$$
Number of posts : 273
Post by PeeWeeMan91 on Wed Jun 30, 2010 1:44 pm
Ok 4 speed freeway flyer but will it bog down driving around the city
PeeWeeMan91
PeeWeeMan91
Post by Bugman114 on Wed Jun 30, 2010 4:52 pm
a freeway flyer came stock in later model beetles if i remember correctly. If your talking about those tranny's with a taller 4th gear, i wouldn't. berg did some experiments with this, and having a taller 4th gear will let you go faster on the highway, but the motor is being worked harder, and the fan is turning slower, and causes the motor to overheat.
Post by PeeWeeMan91 on Wed Jun 30, 2010 5:35 pm
ok so best trannny to get is?
PeeWeeMan91
PeeWeeMan91
Post by 56HAVOC on Wed Jun 30, 2010 6:11 pm
Get a freeway flyer 3:88 it's great and highway speed will be great. I know
Cause that's what I got and I'm good
Number of posts : 1703
Post by PeeWeeMan91 on Wed Jun 30, 2010 6:51 pm
Ok how much would that cost and who would be at to deal with in ga
PeeWeeMan91
PeeWeeMan91
Post by Attorney Isaiah Loophole on Wed Jun 30, 2010 7:09 pm
56HAVOC wrote:Get a freeway flyer 3:88 it's great and highway speed will be great. I know
This is with a 1915cc......what do you have?
Post by PeeWeeMan91 on Wed Jun 30, 2010 7:31 pm
Stock 1600 could I just get the syncros fixed cheaper
PeeWeeMan91
PeeWeeMan91
Post by Attorney Isaiah Loophole on Wed Jun 30, 2010 8:03 pm
If you contact stockornaut they can get yours rebuilt for $300 I think....this is for a swing axle though
Last edited by Attorney Isaiah Loophole on Wed Jun 30, 2010 8:18 pm; edited 1 time in total
Post by PeeWeeMan91 on Wed Jun 30, 2010 8:15 pm
Ok and how much would it be for just a regular new tranny from them
PeeWeeMan91
PeeWeeMan91
