1962 resto.. Patina job
+12
overspray
16 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
https://www.facebook.com/profile.php?id=768229429#!/photo.php?pid=6075157&id=219003816997&fbid=434363746997
new everything.. down to new fuel line and welded clutch tube....
Re: 1962 resto.. Patina job
Thanks... had plans to have her ready for the Eureka Springs Ark. show... but may be close now...
[url=]
[url=]
[url=]
[url=]
[url=]
[url=]
so wht exactly have you done to the body if anything?
pans and everything looks super clean
Thanks !!
Blasted the body, hood and decklid are panted...white base.. then the blue base...buffed to look old and flat cleared
Installing new heater channels
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
very nice. looks awsome. i hope to never have to replace a set of heater channels in my life time, lol. i've been lucky, in that all my cars have always had solid heater channels. even my 61 that had the floor pans rusted away, and even the plywood that was used to replace them was also rotted away
I never wanted to either.. but....
My 63 and 64 both have great chanels too.. I just didnt want to patina a really good body.. now im ready to POR-15 the package tray and door posts and start the priming...
POR15 the heaterchannels as well, that way you'll never have to replace them ever again, .
I drill the botoms off and do the insides...
do all i can to make these cars last...
What product or technique do you use to remove the spot welds? I've been using a reg. drill bit but it leaves thin metal on the piece I need to weld back to.
spot weld bit...until it get dull and then I went to a reg. bit.... just hit the places with a grinder before welding
Rust Bullet applied to package tray and underside... then sprayed with rubberized spray in bedliner.
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
looks good os
- Number of posts : 1416
spray foam...used inplace of the footballs for sound deadening...
[img][/img]
sanding after color.. then a good buffin to make it look faded...
[img][/img]
Taped up to spray the inside gloss
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
Page 1 of 3
