tranny/clutch question 68' type1
Page 1 of 2 1, 2  Next
tranny/clutch question  68' type1 Empty tranny/clutch question 68' type1
Post by 68buggirrl on Tue Jun 15, 2010 9:23 pm
Hey i have a 68 type 1 if that helps
Anyways after it has been driven about 20-30 minutes (I daily to WindyHill from Temple Ga) 1st gear wont stay in and it pops out. Its pretty loud I might add. I finally got it to stay after the fourth time.
Now 2nd gear. Whenever (whether cold or warm) it will make a grinding sound with clutch put all the way in.
/what do I need to look for? Thanks
68buggirrl
68buggirrl
Number of posts : 301
Registration date : 2010-03-20
View user profile https://www.facebook.com/?ref=home#!/bimmergirrl
tranny/clutch question  68' type1 Empty Re: tranny/clutch question 68' type1
Post by Grifspop on Tue Jun 15, 2010 10:35 pm
My '57 Bug is on a '68 Pan, and when my transaxle started popping out of gears (2nd and reverse) my mechanic said it was the input shaft, and recommended I get a new transaxle. I put in a freeway flyer and changed the ratios up a little, it's almost like an overdrive now in 4th.
Post by 68buggirrl on Wed Jun 16, 2010 8:44 am
yikes. What should i check to see if maybe its something else?
68buggirrl
68buggirrl
Post by fluxcap on Wed Jun 16, 2010 8:50 am
I've never had one popping out of gears, but from what I've read, it's a good sign your gonna need another tranny soon. Maybe get your mechanic to take a quick look at your tranny mounts, specifically the front one. I suppose if it were worn pretty bad that could possibly also cause issues.
Post by 68buggirrl on Wed Jun 16, 2010 8:53 am
Okay im going to check the front tranns mount. if anyone else as any other ideas please let me know. I wanna get this fixed before it doesnt drive at all cause its my only car-
Smile
68buggirrl
68buggirrl
Post by drewBAKER on Wed Jun 16, 2010 12:22 pm
my car does the same exact thing in Bertha. it pops out of 1st. I know when i was putting her together i didn't replace my front mount. and now the mount has almost gone bad. and its giving me trouble. so def check that.
Number of posts : 707
Post by 68buggirrl on Wed Jun 16, 2010 12:49 pm
thankyou drew!! Ill have to wait this weekend or fri... I was thinking a mount and hoping it be that and not anything else
68buggirrl
68buggirrl
Post by adams77 on Wed Jun 16, 2010 12:55 pm
I replaced my mount on the 68 baja, the motor/tranny slides back just enough to get them swapped without pulling anything apart.
adams77
Number of posts : 257
Registration date : 2009-01-09
Post by 68buggirrl on Wed Jun 16, 2010 12:59 pm
awesome. do you think harrold in carrollton would have one?
68buggirrl
68buggirrl
Post by Damn-it Don on Thu Jun 17, 2010 2:51 am
If you mean Herrells....I'm sure they would! Razz
Here's their toll free number- 1-866-437-7355
and a link Lindy and da Boyz
Hope you find it's a simple solution! While your under there- check your transaxle, and make sure it's topped off with enough gear oil too. It's easy.
Post by Heinz57 on Fri Jun 18, 2010 10:18 am
If you do find your transmission mount is bad, remember that you should readjust your shifter. I had this problem on my '67 bug, it turned out not to be any mounts, but the shifter itself. Apparently being out of adjustment, when I put the car in gear, it really wasn't 100% in gear. The shifter was not letting the shift forks to fully en-gauge the gear. So under a light load it was staying in gear most of the time, jump on it and it would pop out of gear.
Good luck, maybe its a simple fix!
Danny
Heinz57
Heinz57
Number of posts : 374
Post by 68buggirrl on Fri Jun 18, 2010 1:50 pm
Okay That makes sense as well.
I really dont know too much of what im doing just cause i have nnever messed with a bug trans.
But im guessing it will be self explainatory? haha. If anyone is available sat about noon ill be in dallas at my bf's body shop with the bug fixing it if anyone wants to come by.
68buggirrl
68buggirrl
Post by vw57drvr on Fri Jun 18, 2010 2:58 pm
Good luck, but popping out of gear and being loud USUALLY means the tranny has had it. The noise is usually the main shaft bearing.
Post by 68buggirrl on Fri Jun 18, 2010 3:00 pm
dear god i hope not.
68buggirrl
68buggirrl
Post by Attorney Isaiah Loophole on Fri Jun 18, 2010 3:21 pm
if it ends up being a bad tranny stockornaut has someone that rebuilds them for like 300.....
Post by 68buggirrl on Fri Jun 18, 2010 3:50 pm
okay thats not bad. lol.
Is anyone availble sat/? (In case i run into something)
68buggirrl
68buggirrl
Post by buggin70 on Fri Jun 18, 2010 5:43 pm
i may beable to help
Post by 68buggirrl on Fri Jun 18, 2010 10:20 pm
okay cool. Smile
68buggirrl
68buggirrl
Post by Damn-it Don on Sat Jun 19, 2010 7:24 am
Good luck girl-
Wish I could help, but painting all day, then to the nightshift.
Let us know what you find
Post by 68buggirrl on Sat Jun 19, 2010 6:09 pm
Worked on her Alllll day (since 9am) and did a lot of stuff.
Anyways my trans looked fine. My mount was in good shape. I do smell a sweet smell near my rear passenger wheel. Im thinking it is the break goo. (need a wheel cyl back there.)
Did some research, im going to have to start saving some money for a tranny soon. if anyone has any trans knowledge I can pay you to look at it and fix it if it means saving cash and keeping my tranny.
Besides that i did some bodywork. I have a nice chrome rear bumper and a black muffler now. lol
68buggirrl
68buggirrl
Post by buggin70 on Sat Jun 19, 2010 6:24 pm
68 is a swing axle right?
i have one at the house i was tryin to sell
i think im gunna bring it up to steave cole soon so he can look at it
or your can just have him look at yours?
Post by Damn-it Don on Sat Jun 19, 2010 6:35 pm
^8 was a changeover year on transaxles- she could have a swing or IRS.
Is there 2 axleboots or 4?
Post by buggin70 on Sat Jun 19, 2010 6:36 pm
Don Hall wrote:^8 was a changeover year on transaxles- she could have a swing or IRS.
thats what i thought.
me and tim were arguing that fact lol
tim we were both right
Post by 68buggirrl on Sat Jun 19, 2010 6:44 pm
to be honest i cannot remember exactly. But I am pretty sure four.
68buggirrl
68buggirrl
Post by buggin70 on Sat Jun 19, 2010 6:47 pm
well i dont have a irs tranny
but steave cole may
