rear split window bug safari
rear split window bug safari Empty rear split window bug safari
Post by buggin70 on Mon May 10, 2010 9:13 pm
rear split window bug safari Empty Re: rear split window bug safari
Post by vwgirl on Mon May 10, 2010 9:22 pm
I've only ever seen the kits they sold to make your early bug look like the later bigger windows... that one is pretty cool though.
vwgirl
Number of posts : 332
Post by buggin70 on Mon May 10, 2010 9:23 pm
vwgirl wrote:I've only ever seen the kits they sold to make your early bug look like the later bigger windows... that one is pretty cool though.
id like to have one but im sure if anyone has one they wont let it go
Post by vwgirl on Mon May 10, 2010 9:29 pm
are you sure that isn't custom made? if you could get a split window section you could make one that did that? do they make rear safaris for beetles like that?
vwgirl
Post by buggin70 on Mon May 10, 2010 9:32 pm
vwgirl wrote:are you sure that isn't custom made? if you could get a split window section you could make one that did that? do they make rear safaris for beetles like that?
the guy says its a kit but who knows it could be custom
Post by vwgirl on Mon May 10, 2010 9:45 pm
its a wanted ad and he is wanting info... so who knows...
either way, it would probably be easier to make your own than to find one. That is the only one I have ever seen or heard of
vwgirl
Post by buggin70 on Mon May 10, 2010 9:50 pm
vwgirl wrote:its a wanted ad and he is wanting info... so who knows...
yea same here
Post by DiggerD on Tue May 11, 2010 12:40 am
I think it would be alot better if it was just glass instead of a fake split window......... Evil or Very Mad
Post by vwgirl on Tue May 11, 2010 7:37 am
I agree, but I wonder with all of the curves in the glass how well it actually seals?
vwgirl
Post by DOODLE BUGG on Tue May 11, 2010 10:05 am
creative car craft sells a fiber glass split kit for the back of a later bug an someone more then likly made it from that there self
Post by DiggerD on Tue May 11, 2010 11:25 am
vwgirl wrote:I agree, but I wonder with all of the curves in the glass how well it actually seals?
Probably like crap!! Razz Safari windows are totally flat and they never seal up completely, so I bet this leaks alot. You could probably waterproof the area behind the seat as sort of a catch basin and run a drain down behind the engine tho!! or let it stay full and stock it with some goldfish or something. geek
Post by Grifspop on Tue May 11, 2010 12:11 pm
There was a company back in the nineties that made a fiberglass split window kit, it entailed cutting the vents beneath the window, and glassing in a piece that had the larger vents and split glass. Everyone of those that I ever saw cracked where it was bonded to the car, probably due to engine heat, and different expansion rates of fiberglass and steel.
