Trailing arms do not fit....
Trailing arms do not fit.... Empty Trailing arms do not fit....
Post by petervalle on Mon Apr 26, 2010 7:49 pm
I finally got most of the components to put the front end back on the Bay Window but the trailing arms do not fit inside the beam with the wagenswest beam bushings. I am not to familiar with VW engineering and I am learning as I go. The top of the trailing arm looks too big, in fact I think that it might be a bearing that it is just rusted in place, but all 4 arms look the same. If it is a bearing, how do I take it off. I have not found any pictures that would help me identify the arms. The beam was supposed to be a 66 Bus beam. Any help would be appreciated.
Trailing arms do not fit.... Trailingarm2
Trailing arms do not fit.... Trailingarm3
petervalle
petervalle
Number of posts : 184
Trailing arms do not fit.... Empty Re: Trailing arms do not fit....
Post by Attorney Isaiah Loophole on Mon Apr 26, 2010 8:32 pm
It is a sleeve you can press them off or carefully cut them off. Which bushing did you buy first?
Post by petervalle on Mon Apr 26, 2010 9:10 pm
The guy I got the narrowed beam gets all his bushings from Nate at wagesnwest. The beams are made of new tubing and have no bearings inside. http://www.thesamba.com/vw/classifieds/detail.php?id=825893 This is his ad in samba. It is just a hollow tube. So I talked to Nate and he sold me the same ones, they are red and about a foot long.
Well Bryce, tomorrow I'll take on the task of cutting those sleeves off. I will have to be real careful not to mess this up.
cheers Thanks, you always come to the rescue.
petervalle
petervalle
Post by Uglybug on Mon Apr 26, 2010 9:35 pm
Attorney Isaiah Loophole wrote:It is a sleeve you can press them off or carefully cut them off. Which bushing did you buy first?
Might I suggest cutting most of the way through, then hit from the end with a cold cheisel.
Uglybug
Uglybug
Number of posts : 32
Registration date : 2009-08-24
Post by DOODLE BUGG on Mon Apr 26, 2010 10:13 pm
what they said id use a cutoff wheel
