Engine From Hell
Page 1 of 2 1, 2  Next
Engine From Hell Empty Engine From Hell
Post by 71_georgia_beetle on Sat Apr 03, 2010 12:05 am
OK, I am trying to get the damn gland nut off and I am at a loss. 500 ft lb tq impact wrench and nothing, gallons of PB and nothing, angle iron with a 1/2" breaker and........
Engine From Hell Gland1
3/4" breaker and........
Engine From Hell Gland2
and at the advise of the idiot manual "use a sharp chisel and hit about 1/4" back from tip of one side" and......
Engine From Hell Gland3
It sheers off. I had the angle iron on it, wife standing on the opposite head, 24" 3/4" breaker bar with a 4' cheater and nothing but !!snap!!. Tomorrow, unless you guys have an idea, I will be borrowing my father-in-laws 1" impact wrench. 1200ft lb tq and get it.
Engine From Hell Cp7775-6
Last edited by 71_georgia_beetle on Tue Apr 06, 2010 4:09 pm; edited 1 time in total
Engine From Hell Empty Re: Engine From Hell
Post by rpm750 on Sat Apr 03, 2010 12:12 am
A picture is worth a thousand words!
Engine From Hell AC000133
If you don't have one.. GET ONE!
Post by cavediver520 on Sat Apr 03, 2010 1:56 am
rpm750 wrote:A picture is worth a thousand words!
that was the best money I ever spent. there is no substitute... Laughing
cavediver520
cavediver520
Number of posts : 69
Post by fluxcap on Sat Apr 03, 2010 8:06 am
Yep, the torque tool will take gland nuts and rear axle nuts without you even breaking a sweat! They are only around $65 and you'll use it over and over. I know this probably won't help you now since you already have the engine out and need the nut off NOW, but you should look into getting one for the future. Until then, maybe one of the guys in your area has one you can borrow. Even if you have to drive 30 or so minutes to pick it up, you'll be glad you did!
Post by Bugman114 on Sat Apr 03, 2010 10:39 am
i hope those breaker bars were craftsman, lol. be sure to put some antisieze on there when you get the new nut on. i used antisieze on my gland nuts, and axle nuts. never had a problem trying to get them off again.
P.S. seriously, why the hell do they call it a gland nut? its obviously a really fat bolt. why not gland bolt. i guess it just doesn't sound as cool Laughing
Post by 39coupe on Sat Apr 03, 2010 5:04 pm
Scott, I have one of these if you want to borrow it.
39coupe
39coupe
Number of posts : 455
Post by 71_georgia_beetle on Sat Apr 03, 2010 11:01 pm
I may have to take you up on that. Thanks, I'll let you know.
Post by DiggerD on Sat Apr 03, 2010 11:34 pm
You can always use my BA torque wrench............I garuteeeee it will git that sucker off!!
Post by 71_georgia_beetle on Sun Apr 04, 2010 7:47 pm
Alright Eric, You're up to bat. 250lb and 650lb tq impact wrench, chisel and nothing.........not 1mm. PM sent
Post by vwgirl on Sun Apr 04, 2010 8:00 pm
Everyone should have one in their toolbox! Or at least have one even if you don't have a tool box!
vwgirl
Number of posts : 332
Post by 71_georgia_beetle on Mon Apr 05, 2010 11:22 pm
Thanks to Eric (39coupe), I now have the gland nut off. It didn't happen like I've seen in the videos. I put the torque multiplier on, applied a 1/2" drive ratchet with a 7/16" socket, put my ass in to it and.......................nothing. So, I put on a 4' cheater and ......................snap!. There's a trip to Sears for a ratchet replacement. Then I put on a box end wrench, 6' cheater pipe, balanced myself with with a broom and climbed on...........nothing. So I bounced and bounced and bounced and eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeek! Finally, the damn thing is off!
So, for someone smarter than me, please figure out the total torque value of a torque multiplier, 6' cheater with 208lbs on the end..........bouncing.
There was half a bottle of red loc tite on the damn thing.
Post by Bugman114 on Mon Apr 05, 2010 11:32 pm
hahaha, nice. a little heat would have prolly helped, lol
Post by Grifspop on Mon Apr 05, 2010 11:56 pm
208 lbs on a 6' bar on the torque multiplier, thats a sh!tload of force! Glad you finally got it off, probably won't use that much loctite on reassembly though
Post by Bugman114 on Tue Apr 06, 2010 12:41 am
shit, maybe anti sieze would be better, lol Laughing
Post by bumblebuggy on Tue Apr 06, 2010 8:38 am
Don't use loctite on that thing. The torque will be enough to hold it in place.
Post by rpm750 on Tue Apr 06, 2010 11:35 am
I put mine on with a 3/8 ratchet. That tool multiplies the torque on the roller on the fly, x9.
Post by 71_georgia_beetle on Tue Apr 06, 2010 4:09 pm
I have renamed this "The Engine From Hell". So........I got the gland nut off, flywheel off and then the dreaded heads. All but four of the nuts came off, the rest came with the case bolts. This might be common but a 15mm on a 3/8" ratchet with a 6' cheater and again my fat ass on the other end, just to break torque..........I think is a little extreme. Heads off, jugs off and now the pulley.........oh shit! I put on the CIP1 finest China pulley puller and it straightened out like it was made with four coke cans. So, I load up the engine and take it over to the local auto center and he breaks his Snap On puller and said he was afraid to put to much more on his harmonic balancer. So I bring it back home and let the carnage begin. Whack it from behind with a very large screw driver, nothing. Heat it, whack it and nothing. Steel wedge between it and the case with a 2lb hammer and.....................nothing. Well, I did break my hammer. Engine From Hell DSCN0871
So then I set put for revenge. I bring out the 8lb sledge hammer and start FU*^*ING wailing. At this point my blood pressure was off the scale, I was at whits end and ready to kill something.
Engine From Hell DSCN0867
Engine From Hell DSCN0868
Engine From Hell DSCN0869
Engine From Hell DSCN0870
Last edited by 71_georgia_beetle on Tue Apr 06, 2010 4:17 pm; edited 1 time in total
Post by 71_georgia_beetle on Tue Apr 06, 2010 4:17 pm
Oh and here is the kicker.................the F*&^ING pulley is still on!
NEXT!
Engine From Hell 088381322706?wid=200&hei=200
and then.....
Engine From Hell Claymore-thumb
It will come off!
Post by Damn-it Don on Tue Apr 06, 2010 4:29 pm
"Oh look- Scott must be working on that pully again..."[img]Engine From Hell Nuclea10[/img]
Post by bumblebuggy on Tue Apr 06, 2010 4:36 pm
Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked
Post by aircooledaddicts on Tue Apr 06, 2010 4:54 pm
That is crazy! You have more patience than I do. I would have got mad and took the sledge to the whole engine.
Post by Bugman114 on Tue Apr 06, 2010 9:17 pm
there must be loctite on the pully as well, lol. i would just aim the tourch on the pulley, walk away for 10 mins, come back when its red hot, and take that fucker off Twisted Evil Twisted Evil Twisted Evil
otherwuse, just cut as much pulley off as you can, then split the case, and grind away till you break thru, and it comes off. i'd prolly find the key, and grind on top of that. better to grind away at the key, then the crank itself.
Post by Bugman114 on Tue Apr 06, 2010 9:30 pm
Oh, and your engine is friggin heaven compared to mine. i had the same issues with my car, except now i keep having exhaust leaks, and the heads keep comming loose. VERY ANONYING. the heads are tourqued down to 30FT.LBS, and they still keep comming loose. next time maybe i'll use two nuts, or maybe i'll use a shit load of red locktite, or maybe I'LL JUST WELD THE DAMN NUTS TO THE STUDS Mad Mad Mad !!!!!! i just want to drive the damn thing till it blows up.
sorry rant over Laughing
Post by peregrine67 on Tue Apr 06, 2010 9:50 pm
I'm with Gary. I'd have taken that sledge to the whole block. You have the patience of Job my friend.
Number of posts : 1343
Post by Grifspop on Wed Apr 07, 2010 12:21 am
Looks like you're going to need a new crank by the time this is all over
