Helpful links
Helpful links
General Tech Articles
Volkswagen Paint Codes
Swapping Hockey Stick and Nosecone
Aligning Headlights
Bus Brake Pedal Return Spring Replacement
Type two flipped spindles
Bus flipped spindle install
Center Pin Overhaul
Split Bus Disc Brakes
Distributor Breakdown
Spine Chart
CV Axle Rear Bearing Replacement
Super Beetle Coilovers
Lowered gas charged link pin beetle shocks Monroe part#5752st
Aligning Headlights
Center Pin Overhaul
Spine Chart
Last edited by Attorney Isaiah Loophole on Thu Jun 14, 2018 4:06 pm; edited 15 times in total
Re: Helpful links
Here is a good one for door rebuilding. (scrapers, vent window, etc...)
http://www.dsskvwclub.com/door%20rebuild.htm
Re: Helpful links
Here is my whole collection. Enjoy
Forum and Club Sites
http://www.openroad.ca/volkswebbin/index.php
http://forum.georgiadubs.com/
http://www.athensvwclub.com/
http://www.thesamba.com/vw/
http://jbdb.net/v-web/bulletin/bb/index.php?sid=e8c72d74fc0f73f00733c27c87720cad
http://www.shoptalkforums.com/index.php
http://forums.aircooledtechnology.com/index.php
http://www.aircooledaddicts.org/
http://www.typethreedetectives.com/
http://shop.volkswarenhaus.de/media/content/bugselecta.htm
https://servimg.com/?280057
Parts
http://www.bfyobsoleteparts.com/
http://www2.cip1.com/default.asp
http://www.wolfsburgwest.com/
http://www.iasbugshop.com/index.html
https://www.chircoestore.com/catalog/logoff.php
http://www.vwparts.net/
http://www.dansperformanceparts.com/index.htm
http://www.herrellbugparts.com/
http://www.automotivetouchup.com/choosecolor/choosecolor.aspx?year=1971&make=Volkswagen&model=All Models
http://www.airheadparts.com/page.asp?recid=64
http://www.autozone.com/home.htm
http://www.vwhelp.com/
http://www.vw-resource.com/wiring.html
http://www.ratwell.com/technical/BlueCoil.html
http://www.oldvolkshome.com/ovhignbo.htm
http://www.oldvolkshome.com/ignition.htm#A1971M
http://www.oeveedub.com/
http://www.mamotorworks.com/acvw-1-24-4705.html
http://www.vintagevwcars.com/vwcar.htm
http://www.jbugs.com/store/merchant.mv?Store_Code=jbugs&Screen=index
Resource
http://www.hot-spark.com/
http://www.oldbeetle.net/pcat/epc.html
http://www.vw-classic.net/vwcd_neu/content.pl?src=cp_repleitfaden_typ1_85
http://1800vw.bizhosting.com/year_model.htm
http://www.busselecta.com/bus/
http://www.busselecta.com/porsche/index.htm
http://www.heathland.net/Pics/Resources/VDub_Microfiche/Micro-fiches.htm
http://www.1800vw.bizhosting.com/motor.computer.htm
http://www.type2.com/
http://www.vintagebus.com/
http://www.type-14.com/
http://www.nls.net/mp/volks/
http://www.thesamba.com/vw/forum/viewtopic.php?t=311006
Parts
Resource
Re: Helpful links
http://forum.earlybay.com/index.php
For any other "earlybay-ers" out there....
panic_fan- Dub Nut
- Number of posts : 410
Obsolete Air-Cooled Documentation Project
Found this site a while back while searching for progressive refinements. PR wasn't on this site back then, but it is now. Along with PR (which tells of all the changes over the years by year and chassis number), it also has:
Without Guesswork, which list a ton of specs, tolerances, torques, capacities, etc...
Local manufacture of workshop equipment, which tells you how to make a lot of the VW tools you see listed in the Bentley manuals.
Type II parts reference, which includes diagrams and part numbers for every part on 1950-1967 buses.
SO42 parts list
How to tune solex carbs
And a few other resources.
http://oacdp.org/
SO42 parts list
http://oacdp.org/
