No brakelights
No brakelights
Post by dbcox on Sun Sep 14, 2008 1:19 pm
I dont have any brakelights unless i am at a complete stop and mash very hard on the pedal. They are adjusted right and i have discs in the front. Im thinking maybe one of my switches is going or has went bad. What do yall think? What a Face Oh yeah its , my 74 standard
dbcox
Number of posts : 70
View user profile http://www.lubedealer.com/dbcox
Re: No brakelights
Post by aircooledaddicts on Sun Sep 14, 2008 2:26 pm
I would say it's a switch. I had the same problem a while back and a new switch fixed it.
Re: No brakelights
Post by dbcox on Sun Sep 14, 2008 3:25 pm
I went ahead and ordered a couple. One is fried, Plug connector and all was rusted and coroded and pulled apart. They work alittle better getting the worst one out of the way. Two new ones will fix it i hope. What a Face
dbcox
Re: No brakelights
Post by bumblebuggy on Mon Sep 15, 2008 10:48 am
Seems like 90% of the time it's usually a switch or a ground that's bad when you lose them both.
Re: No brakelights
Post by zabo on Mon Sep 22, 2008 1:54 pm
you get this sorted?
Im having the same probs & more on my 60.
everything was working except my brakelights, I took my lights apart to check the connects etc.. now the turnsignals wont work aghh
Doesnt seem to be the brake switch so i guess im going to have to take a closer look at the turn signal switch
Re: No brakelights
Post by 39coupe on Mon Sep 22, 2008 2:42 pm
I had similar issues with my '65. Ground is a big problem with these. The housing that the bulbs go into have to ground to the car body in order for the lights to work. I found that as I moved this housing around, the lights would come on and go off. I clean up the contact points especial on the little tab at the top of the silver light housing and finally got them all working.
39coupe
Number of posts : 455
Re: No brakelights
Post by dbcox on Sun Sep 28, 2008 3:41 pm
It was the switches,one of them anyway. Now i can tear up atlanta traffic again,with brakelights. What a Face
dbcox
Re: No brakelights
