Shop in Decatur
Shop in Decatur Empty Shop in Decatur
Post by EngineerTEN on Mon Aug 25, 2008 2:19 pm
Gary - I stopped by the aircooled shop down the street from your shop after I left your shop to check it out and see if I can get some lug nuts for the new wheels. There is no showroom. It looks like he does aircooled and watercooled. He had a Golf up on the lift for something - looks like he might be some competetion for your shop. Lots of aircooled VWs on the lot.
They guy took me around back to a workshop where he was working on rebuilding aircooled engines and transmissions. Lots of good used parts everywhere. I also pickup a new oil filler gasket and new fuel pump gasket along with my lugnuts. I've got to tear down the top of my engine to fix a leak from under the oil cooler. the 6mm stud pulled loose. I got an 8 mm from Fluffy to put in but I need to have evertrhing out of the way to turn the tap.
Anyways - here is the address:
Advanced Imports
731 E. College Ave.
Decatur, GA 30030
404-373-7963
Number of posts : 358
Shop in Decatur Empty Re: Shop in Decatur
Post by aircooledaddicts on Mon Aug 25, 2008 9:53 pm
I actually went by there today also. They helped me with my shifter. I modified a bus shifter to work in my bug and they helped me with it. They seemed to be good guys.
Post by aircooledaddicts on Thu Aug 28, 2008 2:52 pm
Just wanted to let everybody know that this is a really good shop and Bobby really knows his stuff. I actually liked it enough over there that I applied for a job there and I will be starting work there on the 15th of this month. I will be an entry level tech basicly and he will be teaching me on the stuff I don't know. I'm excited about it! One, I needed a full time job but 2nd I will be working with VW everyday. How cool is that?! cheers
Post by Attorney Isaiah Loophole on Thu Aug 28, 2008 2:54 pm
If he needs any more help let me know!
Post by aircooledaddicts on Thu Aug 28, 2008 2:55 pm
I'll check with him next week when I go by there.
Post by EngineerTEN on Thu Aug 28, 2008 9:17 pm
That's cool. I wonder if he realizes how valuable it is to have a good mechanic working for him that is active in the aircooled VW comunity.
