Front Clip Replacement Question
Front Clip Replacement Question Empty Front Clip Replacement Question
Post by EngineerTEN on Wed Sep 30, 2009 10:21 am
I was inspecting my trunk area this past weekend and discovered that the car has been hit in the front in the past and not properly repaired. The frame around the fuel tank is bent and you can see the effects of this around the driver side spare tire well. My car is a 1960. The replacement clips available are from 62 which have a different fuel tank. I don't have a problem replacing the front clip with a non 1960 front clip as it is not an original car anyways. The question is, will my original fuel tank fit? If not, could I get a 62 up fuel tank and have that fit? Any other concerns going this route?
Jason
Number of posts : 358
Front Clip Replacement Question Empty Re: Front Clip Replacement Question
Post by bakertim2 on Wed Sep 30, 2009 5:35 pm
No, your tank won't fit unless you replace the entire tank surround. I know of a couple of oval window bugs that may have a good clip on them, however you may have to buy the whole car to get it. You could buy both cars for less than 600. 00, but they are ROUGH, one is a 56(its the worse one) the other is a 54
Post by EngineerTEN on Thu Oct 01, 2009 9:09 am
I can get a early used front clip on the Samba for less. Also, I don't have space to store a car and cut it up. Anyone know if a 62 and up fuel tank will work if I go with a 62 and up clip?
