Shoe to Drum Gap
Shoe to Drum Gap Empty Shoe to Drum Gap
Post by 71_georgia_beetle on Fri Aug 22, 2008 7:26 pm
The new shoes are tapered at the ends.
Shoe to Drum Gap DSCN0432
This leaves a 2.75mm gap at the end of each shoe. Is this normal?
Shoe to Drum Gap DSCN0431
My drums have almost 5mm of surface left. Does anyone know if this is OK or the specs?
Shoe to Drum Gap DSCN0430
Shoe to Drum Gap Empty Re: Shoe to Drum Gap
Post by fluxcap on Fri Aug 22, 2008 9:49 pm
Here are some specs I found on the samba. I don't have my bently around to verify, but I found these specs in more than one thread so they are probably right.
Factory specs are:
New inside diameter = 230mm. (9.055")
Maximum inside diameter is 231.5mm (9.103")
Minimum "wall thickness" is 4mm.
I also read that there should be some specs stamped on the drum itself, may be covered in grime though.
Post by vwovalchild on Fri Aug 22, 2008 10:24 pm
The taper is fine. Just an after market supplier.
Number of posts : 895
Post by 71_georgia_beetle on Fri Aug 22, 2008 10:45 pm
Thanks Flux, I researched it more and found the same thing. Looks like I have a mm or so........or more left and I think that is plenty for steel. I'm not going to turn them this go round so I should be OK. Also, I found nothing on the drums......aftermarket I suppose.
Post by Hobug on Sat Aug 23, 2008 8:01 am
As your picture shows, the newer shoes don't have the exact contour of the drum. This will cause the middle of the shoes to do all the work until they wear down so the whole shoe is hitting the drum when you put on the brakes. It is no big deal; you just have to adjust the brakes as the wear occurs.
Number of posts : 1325
