'64 Sunroof "Geek"
Page 2 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
'64 Sunroof "Geek" - Page 2 Empty Re: '64 Sunroof "Geek"
Post by rpm750 on Tue Nov 10, 2009 8:41 pm
Ok another concept.......
'64 Sunroof "Geek" - Page 2 64BlkBRMs
I like the grey panel instead.
Post by Attorney Isaiah Loophole on Tue Nov 10, 2009 8:44 pm
why not solid black
Number of posts : 4960
Post by rpm750 on Wed Nov 11, 2009 11:30 am
Don't really want to paint the whole car right now, just a thought on the grey panels. To do all that I want right now with the interior, wheels, engine and to just get it rollin again is going to be around $2000. I could opt for stock wheels now and that would reduce it by $700 or so. Either way it has to have tires and I'd rather get the wheels and tires and go from there! I want it on the road by Spring so I can get some use out of that sunroof! Cool
Post by rpm750 on Wed Nov 25, 2009 3:10 pm
Ordered Blk BRM's and tires for the '64.
The Setup....
Front
5.5"x15 BRM w/ 185/60R15 (Same as O'Bugga)
Rear
6.5"x15 BRM w/ 215/65R15
Wheel package, Wheels, Lugs, Center Caps, shipping $595.82 Tires to my door $222
Thats a lot.... affraid
My wife's going to KILL Me...My wife's going to SHIT. Well first she'll SHIT then she'll KILL ME!
Oh well it's only money!
Post by fluxcap on Wed Nov 25, 2009 3:37 pm
Your gonna be in trouble!!!! No Just explain all the money you saved by getting them on sale.
Post by Attorney Isaiah Loophole on Wed Nov 25, 2009 3:44 pm
Where did you get the tires from?
Post by Attorney Isaiah Loophole on Wed Nov 25, 2009 4:16 pm
Just realized you did the 5.5 and 6.5 that is going to be sick!
Post by BKiller on Wed Nov 25, 2009 5:55 pm
You can't fix this Spicolli...
Number of posts : 687
Post by rpm750 on Wed Nov 25, 2009 9:52 pm
I've got a killer tool kit, I can fix it! pale
Attorney Isaiah Loophole wrote:Just realized you did the 5.5 and 6.5 that is going to be sick!
Thanks Bryce, I wanted a deep Rim on the rear. Almost did the 4.5" and the 6.5" but I like a wider tire on front. Didn't think the 185 would look right on a 4.5" rim. I'm going to run the same tires(Falken) that O'Bugga has on it. They ride well and handle well also.
Post by Attorney Isaiah Loophole on Thu Nov 26, 2009 10:18 am
What size are the 8 spokes? (5.5's or 5's)
Post by rpm750 on Thu Nov 26, 2009 7:17 pm
They are 5.5". With about a 4" backspace. Tires came from Discount Tire Direct, free shipping. Would like to see what O'Bugga looks like with them on him!
'64 Sunroof "Geek" - Page 2 Empty Pan Issues
Post by rpm750 on Sat Dec 05, 2009 3:00 pm
Started cleaning the pan for pan halves. I found a couple things that need to be replaced but this will make up my mind on which way to go with it.
The piece that goes over the tunnel is rusted on both sides and someone cut off the support for the pan.See pic....
'64 Sunroof "Geek" - Page 2 OhBuggaClutch001
'64 Sunroof "Geek" - Page 2 OhBuggaClutch012
Replacing pan halves is not fun but requires elbow grease and sweat!!!
'64 Sunroof "Geek" - Page 2 OhBuggaClutch009
Hammer and cold chisel to knock the old spot welds loose.
I'm still not sure what to do about this area. This support was on the new pan half but it was cut off, why? Beats me!
'64 Sunroof "Geek" - Page 2 OhBuggaClutch008
I may build a piece to attach the pan to and then weld it to the support at the back. If you have old pan haves laying around I would like this piece. I'd take those and the new pan and fix it right! The other side is the same. So I'd need both sides. Other than these issues this car is solid. I'll need to replace the lower A pillar hinge on the drivers side of the car along with a patch in the wheel well.
Post by Cambur on Sat Dec 05, 2009 3:51 pm
man, Bob your moving along aswell, as for the rear pan supports, my pan halfs came with them, when i did the pans in my 74 but they looked a little flimsy to me and considering mine were fine i just used the original ones and just replaced the pan itself
keep up the good work!!
Post by 59suicide on Sat Dec 05, 2009 4:51 pm
sweet... cant wait to see how it goes, I plan on doing the exact same thing except mine is passenger hinge and lower pillar and heater channel
Number of posts : 552
Post by rpm750 on Sat Dec 05, 2009 10:14 pm
Thanks guys, I replaced the pan halves in Oh Bugga and I replaced the whole pan half. I had a pro do the lower hinges on both sides. I'm trying to get this thing on the road by Winter Jam. I think I may just make it!
'64 Sunroof "Geek" - Page 2 Empty The '64 has a new name Geekster!
Post by rpm750 on Fri Dec 11, 2009 10:13 pm
'64 Sunroof "Geek" - Page 2 AirCooledGeekSquad
Post by fluxcap on Sat Dec 12, 2009 8:17 am
Hahaha!!! That's a good one. You could go park it up at bestbuy with all the others for a photo. Now quit photoshopping and get to work on that sucker so you can be driving it soon!
Post by fluxcap on Wed Dec 30, 2009 5:50 pm
Bob got his tires mounted on his BRM's the other day so I swung by and took a sneak peak. I couldn't believe the paint scheme he had gone with.
'64 Sunroof "Geek" - Page 2 Pokebob1
Post by rpm750 on Wed Dec 30, 2009 8:35 pm
Ha Ha Ha
Your Chili will be spiked at the Bonfire!
LOL
Post by Attorney Isaiah Loophole on Wed Dec 30, 2009 8:39 pm
What are you talking about Bob it looks "sweet"?! hahaha
Post by rpm750 on Wed Dec 30, 2009 8:53 pm
Yeah, Ok!
But seriously, took the rear drums off today and I'd like to know what the round deal is that is attached to the drum. Looks like some sort of oil catch or something.
I want to run a wider drum on the rear, would you have a set of 4 lugs drilled out for the wide 5 pattern or would you use an adapter plate? Yeah Type 3 drums and all but that route is really not the way I want to go. Will this '64 trans accept the 4 lug drums after I machine the snout? If I go with the 4 lug drums will I have to use the round oil catcher?
Post by Attorney Isaiah Loophole on Wed Dec 30, 2009 8:55 pm
rpm750 wrote:Yeah, Ok!
It is an oil slinger. There is no hole in the backing plate like later cars....
Post by rpm750 on Wed Dec 30, 2009 9:08 pm
I have a set of newer seal caps that I could use, I will be changing the backing plate as well so it has the hole. Just a thought.
Would you run the adapter or re-drill the drum? If you aren't using yours could I borrow them? Just for mock up. They are like 55 bucks per pair.
Post by fluxcap on Thu Dec 31, 2009 5:08 am
Are you keeping drums up front or are you going with discs? If you are keeping drums all around, then I would think the wider drum and extra braking power are a good idea. If you are putting discs up front, I probably wouldn't even worry about the wider drums on the rear, since most of your braking comes from the front and the discs are great.
Either way, definitely get backing plates with the hole. My plates don't have the hole, and I also DONT have the oil slinger or drums drilled for an oil slinger. I constantly have a transmission fluid in my rear drums due to this setup. The rears still have stopping power, but I'm sure it is not what it should be.
Post by rpm750 on Thu Dec 31, 2009 7:15 am
Keeping the drums up front. I may bolt a set of disk on later but for now just drums. I think running the adapter would be ok, Glenn has them on the disk brake kit for the bus. I may need the 1/2" space to clear the tire and trailing arm.
