'64 Sunroof "Geek"
Page 5 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
'64 Sunroof "Geek" - Page 5 Empty Re: '64 Sunroof "Geek"
Post by rpm750 on Wed Apr 07, 2010 9:48 pm
Well took last night off. Went to the Thrashers game and watched them get their butts handed to them, thanks G. A.S. we enjoyed it anyways.
Today I was under the weather, Suspect so I stayed home and got a little done on Geek. Fender beading on the RF Fender, adjusted drivers door/installed upper screws, door handles, door latches, drivers vent window, hood painted but needs another coat at some point, cleaned a bunch of bolts and quarter windows.
I'll have to go to Lindy's Sat and get some parts but it's gettin close and I don't have an engine yet.
Post by rpm750 on Sun Apr 11, 2010 10:44 pm
Little more progress this weekend. Got the interior painted with rattle can paint. Dupli-Color it went on very well and it looks close, a little dull. It's all the same color now!
This is what I started with....
'64 Sunroof "Geek" - Page 5 Assembly4-10-10001
'64 Sunroof "Geek" - Page 5 Assembly4-10-10002
'64 Sunroof "Geek" - Page 5 Assembly4-10-10003
'64 Sunroof "Geek" - Page 5 Assembly4-10-10007
'64 Sunroof "Geek" - Page 5 Assembly4-10-10008
And ended with this...
'64 Sunroof "Geek" - Page 5 Assembly4-10-10009
'64 Sunroof "Geek" - Page 5 Assembly4-10-10010
'64 Sunroof "Geek" - Page 5 Assembly4-10-10011
'64 Sunroof "Geek" - Page 5 Assembly4-10-10012
'64 Sunroof "Geek" - Page 5 Assembly4-10-10013
'64 Sunroof "Geek" - Page 5 Assembly4-10-10015
'64 Sunroof "Geek" - Page 5 Assembly4-10-10016
I also got the Speedo, wiper switch, light switch, ignition switch, grills and gas gauge installed.
'64 Sunroof "Geek" - Page 5 Assembly4-10-10019
I installed the vent window, seals and scrapers...
'64 Sunroof "Geek" - Page 5 Assembly4-10-10018
Got the passenger quarter window installed and found that the rear window that I got with the car is for a later car. Try putting an early window rubber on a window that is about 11 inches larger in circumference, it ain't happenin!
More later.
Post by Attorney Isaiah Loophole on Sun Apr 11, 2010 10:55 pm
Wow that made a big difference! Cant wait to see it rolling!
Post by rpm750 on Sun Apr 11, 2010 11:00 pm
I got all the stuff to latch the doors and I checked my re-keyed locks Gabriel did for me at Bulli last year. They lock but the drivers door will not unlock. The passengers door locks and is real hard to unlock. Think I need to oil/grease them a good bit. They lock like normal just the unlock is hard. Suspect
Still got a lot to do.
Post by ibjamn on Mon Apr 12, 2010 9:02 am
I wouldn't say it is too dull. I like it.
ibjamn
Number of posts : 134
Post by 39coupe on Mon Apr 12, 2010 9:05 am
It's looking great Bob. Making great progress.
39coupe
39coupe
Number of posts : 455
Post by atye on Mon Apr 12, 2010 1:20 pm
Looks like I wasn't the only one busy this weekend!
LOL
Looking great! Let me know if you need any help this week, I'll be free.
Smile
atye
atye
Number of posts : 259
Post by rpm750 on Mon Apr 12, 2010 6:02 pm
atye wrote:Looks like I wasn't the only one busy this weekend!
LOL Looking great! Let me know if you need any help this week, I'll be free.
Smile
Yeah I would of came down and given ya a hand if I were not so busy myself!!!
Post by rpm750 on Mon Apr 12, 2010 9:04 pm
Did some buffing on the paint tonight. WOW what a difference! This paint is going to look great.
'64 Sunroof "Geek" - Page 5 Assembly4-10-10024
'64 Sunroof "Geek" - Page 5 Assembly4-10-10025
'64 Sunroof "Geek" - Page 5 Assembly4-10-10026
'64 Sunroof "Geek" - Page 5 Assembly4-10-10027
'64 Sunroof "Geek" - Page 5 Assembly4-10-10028
Post by 56HAVOC on Wed Apr 21, 2010 5:39 pm
Are you bringing the 64 to the show Saturday? I'm really looking forward to see it. Of you don't bring it I'm going to have to take a trip Newnan to see it. And when you guys going to start up the Friday Nite cruise again. At least let's start with every other week.
Number of posts : 1703
Post by rpm750 on Fri May 28, 2010 9:31 pm
Haven't done much on Geek. I've been putting off doing this.....
'64 Sunroof "Geek" - Page 5 Assembly5-28-10044
Now that looks like a redneck setup!
Fluxcap(Eric) came over today and we raised the body so I could drill out the dreaded broken bolts in the heater channel. Well those are out now and I cleaned all the crevices with a vac and I'm going to install some sound proofing on the package tray and pan. Wish I had a headliner would be real easy to install it now.
We also installed a windscreen....
'64 Sunroof "Geek" - Page 5 Assembly5-28-10053
It has this haze on it from the wipers. Anybody got any way to buff it out?
Post by bakertim2 on Fri May 28, 2010 10:42 pm
I can't wait to see this car rollin.
Post by vwtattooed on Sat May 29, 2010 8:12 am
you can get the haze/scratches out with some 3000 grit wet sand paper and some buffing compound. you can pick up the compound at any auto paint supply store. this can be done with an electric drill or buffer if you have one.
Number of posts : 798
Post by rpm750 on Sun Sep 12, 2010 7:51 pm
I wonder if that headlight restoration stuff will work to clean up the windscreen?
Post by rpm750 on Sun Sep 12, 2010 7:59 pm
Well I worked on Geek today.
I have an engine that I pulled apart and found that the crank is junk so I put it back together and put a flywheel on it and a pulley nut and bolted it up to the trans and clearanced it out for a 200mm flywheel. Looks like I took it to a machinist! Now I can work on the other stuff and take parts from O'Bugga and get Geek on the road for the trip down to Tampa in Nov.
I've got to work out some wipers, I've got 12v and good bit of 6v stuff I'm going to try to put a 12v motor on my 6v frame and see if it will work. I know that the 12v stuff parks one way and the 6v is opposite.
Well it's still freaking hot I hate this damn heat, I'm sick of it!!!!!! Supposed to be nice in the evenings this week.
Post by vwtattooed on Sun Sep 12, 2010 9:55 pm
the man can't make up his mind...gonna sell it or build it? lol!!! i can sooo relate to this dilemma myself!
Post by rpm750 on Mon Sep 13, 2010 4:18 pm
Yeah well no one wants it so I'm building it! Pray that the trans is good to go!
Post by skunk on Tue Sep 14, 2010 8:32 pm
duuuuuuude i had a 59 hardtop painted just like that very cool lookin car
skunk
skunk
Number of posts : 218
Post by rpm750 on Mon Oct 18, 2010 5:36 pm
Ok here he is.........
It's Geek and he's on the road, well for a week now. I wanted to roll up in him when we got ready to leave for Tamp/Bug Jam but since I'm not going this year I want to unveil him now!
'64 Sunroof "Geek" - Page 5 OnTheRoad001
'64 Sunroof "Geek" - Page 5 OnTheRoad002
'64 Sunroof "Geek" - Page 5 OnTheRoad009
'64 Sunroof "Geek" - Page 5 OnTheRoad004
'64 Sunroof "Geek" - Page 5 OnTheRoad003
'64 Sunroof "Geek" - Page 5 OnTheRoad007
'64 Sunroof "Geek" - Page 5 OnTheRoad006
'64 Sunroof "Geek" - Page 5 OnTheRoad008
There are a lot of parts from O'Bugga, Engine, Seats, Fuel Tank, Headlights and a few small items. I love the sunroof, I'll have to figure out how to keep my head from getting blistered next summer! I still have a list a mile long to do but most of that is creature comfort stuff, Carpet, Door panels, Rear Seat and heat.
Thanks to Mr. Conner for this guy he saved him from a yard and I was fortunate enough to purchase it from him. Really solid car it's a '64 w/Steel Sliding Sunroof! My first small window car!
Couple Specs...
2" Narrowed/Adjustable Beam
185/60R15 on 5.5x15 BRM's
One notch in Rear
215/65R15 on 6.5x15 BRM's
They do scrub just a touch on the body to pan connection.
Trans seems to be good to go but I didn't replace the input shaft seal and yeas it leaks badly!
Post by fluxcap on Mon Oct 18, 2010 5:58 pm
Leak, I mean Geek, showed up in my driveway last night. Looked great Bob! Sorry I couldn't get that damn flood light to turn on until you were already down the driveway Laughing
Post by Attorney Isaiah Loophole on Mon Oct 18, 2010 6:27 pm
It looks good! It showed up here on Friday. It fit right in. Very Happy
Post by AlphaOmega on Mon Oct 18, 2010 6:30 pm
Nice looking ride there!!!
AlphaOmega
AlphaOmega
Number of posts : 61
Registration date : 2010-07-10
Post by Cambur on Mon Oct 18, 2010 6:48 pm
looks fresh Bob!
Post by DOODLE BUGG on Mon Oct 18, 2010 7:52 pm
lookes good i have to get on the ball an get the aztec done every one else is geting done iv been working on every ones stuff but tracys oh i hear about it to but thats what paying for parts as we go
Post by rpm750 on Mon Oct 18, 2010 8:20 pm
Thanks Guys...
I do have a problem with the shifter and I can't seem to get anyone on The Samba to answer me so I'll try here. I even asked Lindy and he was clueless.
This is the combination.....
'58-'59 Pan Serial no. 2739764, '58-'59 Shift Rod
Trans Coupler
This one.....
'64 Sunroof "Geek" - Page 5 332714
Now on the pan there is no plastic bushing, it has a metal bracket that is a close/tight fit to the shift rod. If I install a lockout plate under the shifter I can only get it into 3rd and 4th. Oh yeah reverse also.
When I had the plate in it was installed like this...
'64 Sunroof "Geek" - Page 5 411516
I'm wondering if the plate is different for a '58-'59?
Is the shifter different for a '58-'59?
If I used the '64 shift rod would that make a difference?
