Identify These Tires
Post by EngineerTEN on Thu Aug 21, 2008 1:08 am
Anyone know where to find the lower profile whitewalls as seen below?
Number of posts : 358
Re: Identify These Tires
Post by svkustoms on Thu Aug 21, 2008 7:08 am
the only place I would know to even look would be Cocker Tires
svkustoms
Number of posts : 71
Registration date : 2008-08-16
View user profile http://www.myspace.com/svkustom
Post by Hobug on Thu Aug 21, 2008 8:10 am
Most of the low profile whitewalls I have seen were inserts.
Number of posts : 1312
Post by 39coupe on Thu Aug 21, 2008 8:11 am
Hobug wrote:Most of the low profile whitewalls I have seen were inserts.
I was thinking the same thing - porta-walls.
39coupe
Number of posts : 455
Post by Attorney Isaiah Loophole on Thu Aug 21, 2008 12:24 pm
http://www.widewhitewalltires.com/2008Catalog/hi/09.htm
These guys use to have 135 whitewalls but I cant seem to find them.
Number of posts : 4932
Post by EngineerTEN on Thu Aug 21, 2008 12:28 pm
Cool - I'll give them a call.
Post by Attorney Isaiah Loophole on Thu Aug 21, 2008 12:30 pm
Post by Attorney Isaiah Loophole on Thu Aug 21, 2008 12:34 pm
This is my old 61 porta walls all around. 135s up front and 165s in the back.
Post by panic_fan on Thu Aug 21, 2008 2:17 pm
Those walls are awesome. I have never heard of those. When I get new tires for the bus, I may check into those. Anyone seen a bus with them?
Number of posts : 410
Post by Treehive on Thu Aug 21, 2008 4:43 pm
panic_fan wrote:Those walls are awesome. I have never heard of those. When I get new tires for the bus, I may check into those. Anyone seen a bus with them?
Dude, don't put passenger tires on your bus. C rated light truck tires give you a much smoother and safer ride. I'm sure you have read the exhaustive Tire Sticky in the Bay forum of the Samba. Now that I have switched to the proper weight load tires, I will never turn back. Just a bit of friendly advice Very Happy
Treehive
Number of posts : 296
Post by bumblebuggy on Fri Aug 22, 2008 8:06 am
X2!
Make sure you get light truck tires.
Post by panic_fan on Fri Aug 22, 2008 9:06 am
Yea I have tried to read thru the tire sticky...all the whining back and forth kinda annoyed me. Very informative but sometimes tough to sift thru.
I will definitly get the correct tires when I replace them. I guess the portawalls can only be used on passenger tires?
Post by Attorney Isaiah Loophole on Fri Aug 22, 2008 10:39 am
Porta walls will go on anything. Just be aware they take a little to get them to seat properly
Post by Attorney Isaiah Loophole on Fri Aug 22, 2008 10:43 am
what would be the rating for bus tires (what is the two digit number?)
Post by Treehive on Fri Aug 22, 2008 10:55 am
Attorney Isaiah Loophole wrote:what would be the rating for bus tires (what is the two digit number?)
VW recommends a tire with a max load rating of at least 1540 lbs for buses. Here is all the info of the side of my new tires. "Yokohama Super Van 356 185R14 8P, they have a max load of 1850 lbs".
If someone wants to roll their bus with tires that meet VW recommendations, I found there are not a lot of options out there in a 14" tire. I had to be firm with the tire salesman about exactly what I wanted, and the tires had to be shipped in from another state. I have seen too many pics of buses and Vanagons with blown out passenger tires to risk putting anything else on my baby.
PS
sorry to hijack the thread geek
Treehive
Post by Attorney Isaiah Loophole on Fri Aug 22, 2008 11:53 am
Yeah my bus wont have the recommended tires on it. They just dont sell them for lowered buses. 195/50/15 up front and 195/60/15 in the back 82 and 88 ratings. Crying or Very sad Oh well
Post by Attorney Isaiah Loophole on Mon Sep 22, 2008 10:44 pm
Post by EngineerTEN on Tue Sep 23, 2008 1:36 pm
That's really cool. I wonder how they were able to make the perfect circle around the tire.
Post by zabo on Tue Sep 23, 2008 3:18 pm
and another paint your own option:
umm plastic primer
