Budget 1500 SP Build
Budget 1500 SP Build Empty Budget 1500 SP Build
Post by rpm750 on Tue Aug 25, 2009 9:59 pm
Well cleaned the case before opening it up and whatyaknow, cracked freaking case. This engine has a spun #1 rod bearing, I guess it went up and smacked the case top. It runs from the rear top stud up the side and diagonally across to the middle where the bolt and nut is located. I'm hoping some one can weld it up but I'm not sure about the stud, it is loose! Mad
I wanted to use this case it is real nice but not so much now!
I'll post a pic later.
Proflow will just tell me I need a new case....
