broken ebrake
broken ebrake
Post by buggin58 on Sun Aug 23, 2009 10:26 am
my e brake broke
its the lever but idk how to fix it
buggin58
Number of posts : 123
Registration date : 2009-07-15
Re: broken ebrake
Post by Attorney Isaiah Loophole on Sun Aug 23, 2009 11:59 am
Please place tech problems in the technical section.
Did you pull the handle up too high now it is not clicking or did you break a cable?
If you pulled it up too high then you just need to flip the inner catch and then tighten your cables up until it only clicks 5 to 6 times before it stops
Oh and before you adjust the cables you need to adjust the rear brakes
Number of posts : 4927
Re: broken ebrake
Post by Attorney Isaiah Loophole on Sun Aug 23, 2009 12:04 pm
here is a samba reply:
Eric&Barb
"It indeed maybe you broke a cable. Could just as easily be you did not keep the brakes adjusted properly!
Either way the below applies!
Yes, you need to figure how to put the E-brake back together. The ratchet pawl is now upside down in the handle. Look under the handle to see it when pulling up on the E-brake handle.
Pull the button and the rod it is screwed onto out of the handle and see how the rear end of the rod has a curve to fit the top of the ratchet pawl.
Reinstall the button and rod with curve in correct direction. lift the handle all the way up. If you can not get it high enough to have the pawl clear the ratchet gear under there you might need to loosen the E-brake cables a bit. Flip the pawl so as to engage the button and curve in the rod. Then with the button still depressed lower the E-brake enough so the pawl engages the lower gear.
Then replace if you have a broken E-brake cable.
BTW anytime you have the rear drums off it is a prime time to remove the brake stars for wire brushing and applying a never seize to keep those stars getting stuck from rusting up.
THEN adjust your brake shoe adjusting stars!!!
THEN AND ONLY THEN adjust the E-brake cables.
After this make sure your E-brake only pulls up 4-8 clicks.
Over 8 clicks and the E-brake will come apart again!!
For stongest working and longest lasting brake shoes, you need to adjust brake stars anytime you get to 6 clicks or even sooner."
Re: broken ebrake
Post by buggin58 on Sun Aug 23, 2009 1:11 pm
my bad i meant it for people in dallas to help me
sorry
but yea i lifted it too high
i flipped the pawl but i have to press it to the gears w/ mt finger
like it dosnt spring back but im goin to the shop tomarrow
so my grandpa can look at it
thanx now i can drive it to school tomarrow
any advice on my problem now plz tell me
buggin58
Re: broken ebrake
Post by skunk on Tue Aug 25, 2009 11:17 am
ya dude like bryce said..if the ebrake isnt clickin when you raise it or if its not stayin up when you pull on it..then its your lil lever on the inside of the lever. just loosin the cables take the ebrake lever off an flip the lever..make sure the button arm is underneith the lever or it want lock and you will still have the same prob.
skunk
Number of posts : 218
Re: broken ebrake
