Holy Smokes....
Holy Smokes....
Took the clan for a scenic drive on GA 384 (Richard B Russel Scenic Highway) and after a long ascent up the mountain, my brakes started smoking on the way down the mountain....first we noticed a strange smell and when I finally pulled of the road, there was smoke coming from all four wheels .....primarily the front wheels. Thoughts? Suggestions? The brake system of the Hive is one that I have not delved into too deeply yet, so someone please tell me I'm not f***ed. I can handle the oil leak, but not being able to take a Westy to the Mnts for some camping is bordering on rediculous. Thanks.
T
T
Treehive- Dub Nut
- Number of posts : 296
Re: Holy Smokes....
When we take the squareback out in the mnts i try not to use the brakes as much as possible,let the engine slow you down even if you have to go a little slower.
Re: Holy Smokes....
Allways use lower gear when coming down a steep grade in the mountains.
Have you seen the run-a- way ramps for big trucks. Durned up breaks from riding them.
Re: Holy Smokes....
Yeah, what they have all said. Your brake are probably fine, you just need to use your gears to slow you down. Lower gears and slower speeds on the down hill are the answer.
Re: Holy Smokes....
Ok....I was just coasting down the mountain riding the brakes, but I had no idea that would cause a problem. I'll just cruise down in 1st and 2nd next time. Thanks
Treehive- Dub Nut
Re: Holy Smokes....
Good Information to Know....Thanks
panic_fan- Dub Nut
- Number of posts : 410
