Single or Dual??
Single or Dual?? Empty Single or Dual??
Post by 28shows.28days on Fri Jun 12, 2009 7:59 pm
What is your opinion on single port and dual port... which is better?
28shows.28days
Number of posts : 15
Registration date : 2009-05-11
Single or Dual?? Empty Re: Single or Dual??
Post by fearthefat138 on Fri Jun 12, 2009 8:28 pm
in my opinion single for daily if your not worried about power
fearthefat138
fearthefat138
Number of posts : 275
Post by aircooledaddicts on Fri Jun 12, 2009 9:42 pm
Dual port your going to get a little more power on the top end. Unless you are building a big engine I would stay with single port. I am running a 1600 sp in my bug right now and it has good power for a daily driver. I drive it everyday and 75-80 mph is no problem at all.
Post by jshmnghm on Fri Jun 12, 2009 9:47 pm
I run a 1500 SP in my 70 Beetle. Had heads ported/polished and installed a 1 3/8 merged header w/fat boy muffler. Runs 75-80 all day.
Number of posts : 311
Post by rpm750 on Fri Jun 12, 2009 9:52 pm
Now Gary, we older dudes need to set an example for the younger dudes! He means 75-80 kilometers per hour, didn't you Gary......
I have had both and for my commute each day it is stop and go thru red lights. I like the Dual port better after getting rid of the non-vacuum advance dizzy and installing a vacuum advance dizzy it is even more enjoyable to drive. Yes it will run 130 km/h(80mph)! Laughing
Post by billieco on Fri Jun 12, 2009 10:10 pm
SINGLE!
billieco
billieco
Number of posts : 305
View user profile http://stockornaut.com
Post by tito on Sat Jun 13, 2009 1:58 am
my 1200 does just fine as my daily. although i would like a bit more ooomph at times, it easily cruises at 75mph.
Number of posts : 205
Post by Bugman114 on Sat Jun 13, 2009 7:58 am
personally i really can't tell the difference. perhaps if you went all technical with dyno sheets and stuff like that, you may see a little difference, but otherwise, there really isn't much of a difference IMHO.
Post by 28shows.28days on Sat Jun 13, 2009 8:10 am
so everyone is saying a 1600 stock single can run 75 80 all day long with out messing with the engine or is there something else needed to run 75 80. cause i have a 1600 single pretty much stock...
28shows.28days
Post by aircooledaddicts on Sat Jun 13, 2009 8:37 am
28shows.28days wrote:so everyone is saying a 1600 stock single can run 75 80 all day long with out messing with the engine or is there something else needed to run 75 80. cause i have a 1600 single pretty much stock...
Yes, your stock 1600 single will run that just fine with nothing else needed.
Post by Bugman114 on Sat Jun 13, 2009 8:38 am
When i had my 1600 dual port, the top speed on tha highway was about 85 for me. that was with the pedal all the way down, on flat land. any little hill would slow me down to about 80, and any of those long steep hills about 75 to 70ish. And that was with a freshly rebult 1600 dp, but i did have a low CR (about 7-7.5). so i'm guessing with a bit higher CR, it would prolly have a bit more power to it. But now with my turbo, i can cruise 95-100 all day long, and still have some power left....... don't ask me how i know that Twisted Evil
Post by 28shows.28days on Sat Jun 13, 2009 8:43 am
well thanks everyone for all your info... when is the next meet i would love to meet everyone
28shows.28days
Post by aircooledaddicts on Sat Jun 13, 2009 10:34 am
We will be meeting at Nacho Daddy's this Thurs. and would love it if you could make it. Also, the last weekend of this month we are cruizing to Helen and going tubing. Very Happy
