Little gremlins making me nuts
I've been finishing up my 53 split and have a couple of things I can't figure out.
I can't get it to shift into first and second gear.
My generator light doesn't come on when I turn the key on,the oil light does
Turn signal indicator light doesn't come on.
Any suggestions?
Thanks, Bill
Any suggestions?
Thanks, Bill
Fine 53- Dub Noob
- Number of posts : 3
Registration date : 2016-12-06
Re: Little gremlins making me nuts
Do you have the lockout plate installed correctly under the shifter? Is it a stock transmission? The generator light works directly from the regulator. Maybe the points inside are stuck. Does it actually charge while its running? I assume you are running semaphores? There is a wire from each semaphore going to the same bulb in the dash. The other side of the semaphore runs to the turn signal switch. Do you have this diagram?
http://www.thesamba.com/vw/archives/info/wiring/bug_todec53.jpg
vw57drvr- Complete Dub Addict
- Number of posts : 902
Thanks for the reply. I've looked at the shift plate and am pretty sure it's in there right from the photos I've seen. I tend to think that it might be the hockey stick. The tyranny was the only part of the whole car that I farmed out. I restored every nut and bolt on it. Zwitters are a little different on the wiring. I would like to find an excellent competent shop if there's any that can be recommended.
Thanks, Bill
Thanks, Bill
Fine 53- Dub Noob
I do have that diagram. I changed the electrical to 12 v and put the regulator under the back seat. Checked the wire from it to the right. It could be a regulator issue. I'll check it. Thanks.
Fine 53- Dub Noob
If you have a later tranny in there with a bus nosecone, those are a pain to get right. I had to use a bolt at the connector so I could loosen it and move it. Once I finally found where it would go in all gears, I drilled a divet in the hockey stick and used the stock bolt.
» Making an old dealership new again!
» What wheel lug nuts look best for my wheels ????
» The secret of front wheel nuts
» so im gunna start making care packages for soldiers over seas
» Turtle back lugs & nuts / Lugstud questions...
