Pulley take off
Pulley take off Empty Pulley take off
Post by Alansd on Sun Jun 12, 2016 9:24 am
Gotta take off the crank pulley to put in the breastplate tin. Anyone have a pulley PULLER or another method I can try? Also How do you get a socket wrench on that big ass nut?
Alansd
Number of posts : 93
Registration date : 2015-04-30
Pulley take off Empty Re: Pulley take off
Post by vw57drvr on Sun Jun 12, 2016 10:20 am
Use a wrench on the nut if you can't get a socket on it with the rear tin off. Once that is off, put your hand on one side of the pulley and pull. At the same time, tap the other side with a dead blow. You can use a regular hammer too, just don't hit it as hard. It will move slowly at first. The problem with pullers is they will bend the pulley. And it's almost impossible to use with it in the car.
Post by Alansd on Sun Jun 12, 2016 8:23 pm
ok thanks for that tip
Alansd
Post by 57RTOval on Mon Jun 13, 2016 9:54 pm
Number of posts : 529
Post by 57RTOval on Mon Jun 13, 2016 9:56 pm
Post by type4revolution on Tue Jun 14, 2016 11:52 am
J bug option tool works well.
Number of posts : 907
